Want to add to search result pane (without search page) [message #18416] |
Fri, 09 May 2003 11:09  |
I want to contribute some results (from IJavaElements) to the search pane.
I am currently using:-
IMarker im =
element.getResource().createMarker("org.eclipse.search.searchmarker ");
im.setAttribute(IMarker.LINE_NUMBER, detailed.getSourceLineNumber());
im.setAttribute(IMarker.MESSAGE, elem.toString());
This code works if create an IMarker.TASK but not with the the search
marker. How can I contribute to this view in a simple way, without the
gumpf (sp?!) or creating a pane? Any help would be great, thanks.
Jon
Re: Want to add to search result pane (without search page) [message #19326 is a reply to message #18432] |
Sun, 11 May 2003 16:29  |
Thanks, I'll give it a whirl.
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:b9ghke$scg$1@rogue.oti.com...
> Jon Hatcher wrote:
> >Hi,
pane.
> >IMarker im =
> You can't. In contrast with the Task view the Search view is generic.
> Depending on the search provider the elements are rendered different
> (e.g. resources vs. Java elements vs. help results) and also different
> actions are available on the results.
> You don't need to provide a search page but you have to tell the Search
> view what kind of results will come in (see ISearchResultView for more
> detail). When performing your search it is also much fast if you do it
> in a single WorkspaceModifyOperation instead of adding each result one
> by one (which causes overhead due to resource delta events).
> HTH
> Dani
FUDForum. Page generated in 0.04187 seconds
