Re: Which CVS-NT version should I use with I20040212 under Windows-XP [message #195451 is a reply to message #193795] |
Mon, 16 February 2004 13:20  |
Originally posted by: Michael_Valenta.oti.com
The problem is that CVSNT is a forked codebase from *nix based CVS which
makes it difficult to support fully. Problems are also arising with
the latest versions of *nix CVS (i..e 1.12.* has some incompatibilities
with Eclipse). The root of the problem is that Eclipe uses the CVS text
messages to provide advanced funtionality such as the Synchronize view
and Repositories view. What is planned for 3.0 is a statement indicating
the Eclipse CVS funtionality that is supported for all CVS versions
(CVSNT included) and the functionality that relies on text messages
which may be broken by server changes (i.e. the CVS developers do not
consider the message format part of the CVS protocol and therefore may
change the messages at any time). The basic functionality are things
like Team>Update, Team>Commit, checkout, etc.
Michael
John MacEnri wrote:
> None as far as I can see, which seems a pity.
> Though I've been using CVSNT 2.0.14 with Eclipse 2.1.2 for a while now
> without any problems.
> (I heeded the advice of not using repository prefixes)
> "Zsolt" <unknown@nodomain.com> wrote in message
> news:c0g9dv$vl1$1@eclipse.org...
>>Hi,
>>I see the following warning on the CVS-Console:
>>Warning: Host 'localhost' is running CVS NT (version 2.0.14) which is not
>>fully supported. However, most functionality is available.
>>Which CVS-NT version is fully supported?
>>Zsolt
FUDForum. Page generated in 0.03484 seconds
