Home » Eclipse Projects » Eclipse Platform » long delay on startup (5/10 min)
long delay on startup (5/10 min) [message #193224] Thu, 12 February 2004 08:08 Go to next message
Originally posted by: kompass.epigenomics.com
Hi all!
I'm experiencing a tremendous delay on every startup of Eclipse.
Working under a debian Linux system with a 3GHz intel idle during
all this startup delay, I can't figure it out why.
Depending on the exact version, I get like little over 10 minutes
delay with 2.1 or 2.1.2 release versions vs. 5 minutes with 3.0-M6.
After this delay the app works "quite normal".
All I did was local user install (no access rights probs) and
execution of like "$> ./eclipse" in the appropriate dir.
Anybody have an explanation for this and how to get around delay ?
Sascha
Re: long delay on startup (5/10 min) [message #193344 is a reply to message #193224] Thu, 12 February 2004 10:08 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Sascha Kompass wrote:
> Hi all!
Did you try a profiler? Did you file a bug report?
Dani
> Sascha
Re: long delay on startup (5/10 min) [message #193384 is a reply to message #193224] Thu, 12 February 2004 10:51 Go to previous messageGo to next message
Originally posted by: douglas.pollock.magma.ca
I agree with Daniel Megert: File a bug.
Do other applications start-up slowly? KDE, for example....
Doug.
Re: long delay on startup (5/10 min) [message #193775 is a reply to message #193384] Fri, 13 February 2004 03:53 Go to previous message
OK, will do so first after getting back to my working place.
Wanted to hear from community first as I've seen nothing like this
in Google or in bug database search. Still believe it has sth to do
with personal settings or the like :o/
Nothing unusual so far, should try some heavy GTK app though ..
Thanks for advice,
Sascha
Re: long delay on startup (5/10 min) [message #193782 is a reply to message #193224] Fri, 13 February 2004 03:43 Go to previous message
> Hi all!
What JVM do you use ?
> Sascha
Previous Topic:How do I know if content assist is open in a sourceviewer?
Next Topic:cursor problem
Current Time: Fri Nov 07 14:57:56 EST 2025
Powered by FUDForum. Page generated in 0.03825 seconds
