Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Execute required files in Ruby?
Execute required files in Ruby? [message #18377] Fri, 14 December 2007 16:17 Go to next message
Originally posted by: martin.thiede.gmx.de
has anyone every thought about executing ruby code from required files
in DLTK, e.g. using JRuby?
Then not only methods derived by the parser could be provided for auto
completion, but also dynamically added methods as they are returned by
the Object#methods.
I'd also appreciate your answer if you know why this won't work or is
off topic for DLTK.
Kind regards,
Martin
Re: Execute required files in Ruby? [message #19244 is a reply to message #18377] Mon, 17 December 2007 01:12 Go to previous messageGo to next message
Hi Martin,
We have such functionality, we called it builtin modules.
We generate fake modules for builtin elements. They are available to explore from Interpreter Libraries/(builtins).
I've fixed JRuby builtin module retrieval code, so it will works to, thanks.
Fix will be available in next integration build.
Andrei.
> Hello,
> the Object#methods.
> off topic for DLTK.
> Kind regards,
> Martin
Re: Execute required files in Ruby? [message #19387 is a reply to message #19244] Thu, 20 December 2007 17:22 Go to previous message
Hello Andrei,
good to hear that you have a solution for my problem :o)
Unfortunately it doesn't seem to work. I tried it with the latest
integration build I200712200523 but without any success.
Here is my simple example:
In one file "SomeClass.rb" I have:
class SomeClass
define_method :cc do
puts "cc"
end
end
In another file I do:
require 'SomeClass'
o = SomeClass.new
o.<ctrl shift>
But it doesn't show me the "cc" method.
What am I doing wrong? Or do I have to configure something?
Martin
Andrei Sobolev schrieb:
> Hi Martin,
> Best regards,
> Andrei.
>> Hello,
>> the Object#methods.
>> off topic for DLTK.
>> Kind regards,
>> Martin
Previous Topic:Hover Information
Next Topic:PreferencePages
Current Time: Sun Aug 31 23:43:36 EDT 2025
Powered by FUDForum. Page generated in 0.45891 seconds
