[ANN] MyEclipse Enterprise Workbench- 2.7 GA Release [message #18372] |
Sun, 07 March 2004 22:07 |
Originally posted by: masrim.comcast.net
New Product Release Now Available - (www.myeclipseide.com)
Version 2.7 GA (Generally Available) includes significant new Struts and XML
productivity features, application deployment enhancements, and general
maintenance updates. New and Noteworthy Features for MyEclipse 2.7 include:
*Struts Development Tools*
Web-Struts Project - Add Struts 1.0 or 1.1 Capabilities to any MyEclipse Web
Project. The process automatically populates a web project with Struts
libraries, taglibs, and Struts XML configuration, and updates web.xml.
Struts 1.0 and 1.1 Wizards - Wizard-driven generation of Struts
configuration elements and their corresponding Java, web.xml entries, and
JSP code. The new creation wizards enable you to create Modules, Actions,
Forms, Forwards, Exceptions, DataSources, MessageResources, and Plugin
entries. A special workflow wizard is provided to create Form, Action, and
JSP entities in one easy step.
Advanced Struts Configuration Editor - A multipage editor provides a
synchronized XML source view with syntax coloring and smart code completion,
interactive outline view, and experimental graphical flow-view. XML source
editing supports the new integrated XML editor with code completion and
validation.
Struts JSP Templates - Use MyEclipse templates when creating JSPs
pre-configured to use Struts taglibs.
Struts Configuration Validation - This release provides XML validation. A
future release will provide comprehensive semantic validation of an
application prior to deployment.
*XML Development Tools*
Smart Code Completion - Rapidly edit any XML file using smart grammar-based
code completion
Syntax Coloring - View XML source with colorized syntax based on user
configurable coloring rules
XML Validation - Automatic and manual validation of XML files. XML errors
are marked within the XML Editor or from the Eclipse TaskView.
DTD Repository and Caching - Developers can work more quickly and offline
with the new DTD repository and caching features. The MyEclipse XML
repository ships pre-populate with a large number of common DTDs. The XML
Editor and Validation tools with the configurable option for suppressing the
downloading of un-cached DTDs.
File Encoding Support - The XML Editor honors the file encoding specified by
the its document.
New XML File Wizard - Take advantage of 4 different MyEclipse XML templates
when creating a new XML files.
*Deployment Features*
Linked Deployment - The MyEclipse Application Deployer now recognizes and
traverses Eclipse linked folders and files. It is no longer required to make
local copies of shared resources per project.
Deployment Status Information - Displaying any deployment status messages
that are returned from deploying a J2EE module to an application server to
help in debugging project deployment problems.
2.7 GA support Eclipse 2.1 and 2.1.2. Support for Eclipse 3.0 M7 will be
available next week. Starting with this release, MyEclipse 3.7 will be
available for all to download, including trials.
For more details on defect and bug fixes, please review the release notes
available at the MyEclipse portal. -
www.myeclipseide.com/index.php?module=ContentExpress&fun c=display&ceid=27
FUDForum. Page generated in 0.03223 seconds
