| Line Numbers Not Displaying [message #18343] |
Thu, 27 January 2005 17:15  |
Originally posted by: chris.montgomery.lackland.af.mil
I have the option checked to show line numbers under Text Editors in
Preferences, however, the line numbers aren't displaying. Anyone else
having this problem? Is there a fix?
Running Eclipse Version: 3.1.0, Build id: 200412162000 on Windows 2000.
| Re: Line Numbers Not Displaying [message #19646 is a reply to message #18389] |
Fri, 28 January 2005 09:47   |
Darin Swanson wrote:
> What type of file are you opening? Java source code? Ant buildfile, text
> file etc
> In Eclipse, editors are opened based on file content and/or file extension
> as set in the Window>Preferences>General>File Assocations
> I am not trying to be difficult :-) but in M4 the preferences were in a
> state of flux (the specific editor settings were being replaced by general
> editor settings for things like displaying line numbers). So we might have
> introduced a bug (scanning the Eclipse bugzilla I could not find any current
> report).
> Knowing exactly what you are trying to open in an editor, I can reproduce
> your problem (or not).
Thanks for the comeback, Darins. Ok, I was opening .cfm (ColdFusion)
templates before. I just tried opening plain ascii text (.txt), .asp, and
htm files. Of those, the .txt and .asp files DO show line numbers, the
cfm and .htm DO NOT show line numbers.
Thanks again!
| Re: Line Numbers Not Displaying [message #26426 is a reply to message #25199] |
Mon, 07 February 2005 17:25  |
> My apologies...let this one slip.
No problem.
> If I remember you were opening files that I did not recognize the extensions
> of.
> (Can you remind me what the exensions where?)
Per my previous post (
http://www.eclipse.org/newsportal/article.php?id=234&gro up=eclipse.newcomer
), I was opening .cfm (ColdFusion) templates. I also tried opening plain
ascii text (.txt), .asp, and htm files. Of those, the .txt and .asp files
DO show line numbers, the cfm and .htm DO NOT show line numbers.
> Do the editors that these are opened within support line numbers?
I suppose they do, I was using the default editor in Eclipse.
Thanks.
FUDForum. Page generated in 0.10085 seconds
