| unable to import javax.mail.* into java files in Eclipse [message #192573] |
Wed, 07 February 2007 17:01  |
Originally posted by: satsuv.msn.com
I am using the latest version of Java (jdk1.6) and Eclipse. I also
downloaded JavaMail API and the jaf framework. I added both the mail.jar and
activation.jar to the CLASSPATH variable in Windows XP. I am able to run the
javamail sample programs from the command prompt. However, I get an error
message in Eclipse - import of any classes from the javamail api gives me an
error message. What could be the reason? Anyone else run into the same
problem?
Su
| Re: unable to import javax.mail.* into java files in Eclipse [message #192849 is a reply to message #192626] |
Thu, 08 February 2007 15:13  |
Originally posted by: eclipse5.rizzoweb.com
Charle Kelly wrote:
> Hi Su,
> One solution is to use the PDE wizard to create a plugin from existing
> jar files (mail and jaf). Then make your project dependent on the new
> plugin.
> This technique works well for me.
While it works, that is not the most direct or simplest way to go about
it. Most Eclipse users don't know anything about the PDE or creating
plugins.
Far simpler is to import the JARs into the project. If the same set of
JARs are needed by multiple projects, you can either create a User
Library and add that to each project's dependency, or create a small
Java Project that contains the JARs, add them to its build path, and
then make other projects depend on that one.
Hope this helps,
Eric
FUDForum. Page generated in 0.10110 seconds
