| some notes to make imp work for 3.3/3.4m5 [message #18289] | Tue, 25 March 2008 03:28  |  |
| Eclipse User  |  |  |  |  | The offical version for eclipse 3.3(or higher) seem in a very low priority. But I sugguest imp committers to deal with this request soonly.
 If we are extremely anxious, we should do it ourselves:)
 I wrrite some notes here in some experiments today. And I hope this may
 answer some questions about this topic to some extent.
 1. make all prerequisites ready in your workspace.
 see more: http://eclipse-imp.sourceforge.net/developers/index.html
 notes: for me, lpg.runtime.java(and its dependencies) source ,
 com.ibm.wala.shrike source, and polyglot binary
 2. get the source from offical svn.
 see more: http://www.eclipse.org/imp
 3. some compiling error will appear after step 1,2. Then, we should
 "Building Required Parsers".
 notes: build every *.g files. Some projects seem been removed in offical svn
 , such as "org.eclipse.imp.java.core", just remove or ingore some
 instructions in the "IMP Developer's Corner".
 4. close some un-completing projects(in my understanding?^_^) and
 notes: I close *.formatting,*lpg.analysis.
 I add some guessed-implenmentation to *.box
 and *.leg. But I'm not sure they will work really^_^ So you can close them
 as well.
 sdf_eclipse_install,*.pbd seem not existing. So close/ingore/remove their
 infos. Remember to DO some cleaning in MF files.
 5. arrive here, you will see a litte compiling errors in *imp.mattooling and
 *lpg.runtime. There are main errors caused by the API migration. trrival to
 correct them.
 note: I don't use the patch by Karl(see more:
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=221887), the patch seem
 seriously to modify the orignal imp. I'm not very sure it is neccessary.
 6. After some fixes, there should be no compiling errors.But in fact, there
 some runtime errors.
 notes:1>
 LanguageRegistry#updateEditorRegistry
 should use display.asyncExec() to avoild "invalid thread access"
 2> a building mistake in *lpg.metatooling make it stop loading when running
 form workspace.(maybe pass after deploying?) Delete the "jikespg.jar" in
 "Building Configuaration" page, and recorrect them.
 7. After 1-6, the basic functionalities seem ready to use. And I migrate the
 imp to 3.3/3.4m5. seem no big problem^_^
 I add a snapshot in the attachment.
| Re: some notes to make imp work for 3.3/3.4m5 [message #18361 is a reply to message #18344] | Tue, 25 March 2008 22:38  |  |
| Eclipse User  |  |  |  |  | Bob:
 great work, bob. my recent interesting thing is some language enviroment
 creation. I think imp is a great step in this directtion.
 we need a work base to help community grown. So, I sugguest to releasing a
 workable milestone soonly.
 I will try imp more.:) Some collaboration between jdt(and xxxdt), wtp, dltk
 seem possible.
 Jin
| Re: some notes to make imp work for 3.3/3.4m5 [message #570028 is a reply to message #18289] | Tue, 25 March 2008 10:20  |  |
| Eclipse User  |  |  |  |  | Jin wrote: > The offical version for eclipse 3.3(or higher) seem in a very low priority.
 We do understand that it's important, but we were just swamped with
 other facets of getting the IMP project up on eclipse.org (navigating
 the IP process, for example), and attending EclipseCon last week.
 Your contributions are *extremely* helpful; thanks!!! This is what
 makes the Eclipse community a great thing to be a part of!
 Anyway, we'll be folding the necessary changes into the code base
 very soon. Stay tuned!
 -- Bob
 Robert M. Fuhrer
 Research Staff Member
 Programming Technologies Dept.
 IBM T.J. Watson Research Center
 IMP Team Lead (http://eclipse-imp.sourceforge.net)
 X10: Productivity for High-Performance Parallel Programming (http://x10.sf.net)
| Re: some notes to make imp work for 3.3/3.4m5 [message #570059 is a reply to message #18344] | Tue, 25 March 2008 22:38  |  |
 seem possible.
 Jin
FUDForum. Page generated in 0.05728 seconds
