| Unhandled exception caught in event loop. [message #18281] |
Wed, 28 August 2002 09:04  |
Originally posted by: bkandan.selectica.com
hi,
i wrote an editor extending GraphicalEditorWithPalette...when i try to
run my program as a Runtime-Workbench, i get this error message "unhandled
exception caught in event loop"...what is the cause for this error...
Thanks in advance...
Balaji...
| Re: Unhandled exception caught in event loop. [message #18332 is a reply to message #18315] |
Wed, 28 August 2002 09:15   |
This is the error message in the log file...
!SESSION Aug 28, 2002
18:44:53.755 ---------------------------------------------
java.version=1.3.1_02
Command-line arguments: -dev bin -data D:\eclipse\runtime-workspace -os
win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 Aug 28, 2002 18:44:53.755
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Aug 28, 2002 18:44:53.765
!MESSAGE process.editors.CxProcessEditor
!STACK 0
java.lang.ClassCastException: process.editors.CxProcessEditor
at org.eclipse.ui.internal.EditorManager$1.run(EditorManager.ja va:460)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
org.eclipse.ui.internal.EditorManager.openExternalEditor(Edi torManager.java:
453)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager
..java:430)
org.eclipse.ui.internal.EditorManager.openEditorFromInput(Ed itorManager.java
:304)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:386)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1680)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1575)
org.eclipse.ui.wizards.newresource.BasicNewFileResourceWizar d.performFinish(
BasicNewFileResourceWizard.java:95)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:577)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:312)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:398)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:87)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:827)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1529)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1291)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:557 )
at org.eclipse.jface.window.Window.open(Window.java:537)
org.eclipse.ui.internal.NewWizardShortcutAction.run(NewWizar dShortcutAction.
java:88)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:749 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:407)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionCont
ributionItem.java:361)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionI
tem.java:352)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(A
ctionContributionItem.java:47)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1177)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1160)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:775)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:432)
at EclipseRuntimeLauncher.main(EclipseRuntimeLauncher.java:24)
"Randy Hudson" <hudsonr@spam.com> wrote in message
news:akiha5$lc7$1@rogue.oti.com...
> Whenever you get this, a .log file is generated in $WORKSPACE$/.metadata
> You'll have to post this .log file with the exception, but it is
cumulative,
> so make sure you delete it and then reproduce the exception.
> "netbeans" <bkandan@selectica.com> wrote in message
> news:akih3o$l8p$1@rogue.oti.com...
> > hi,
to
"unhandled
> > Balaji...
| Re: Unhandled exception caught in event loop. [message #18720 is a reply to message #18332] |
Fri, 30 August 2002 10:36   |
isnt there any solution for my problem....
pls somebody help...
Balaji....
news:akihoc$ln7$1@rogue.oti.com...
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> 453)
> at
> .java:430)
> at
> :304)
> at
> at
> at
> at
> at
> at
> at
> at
> java:88)
> at
> at
> at
> tem.java:352)
> at
> at
> a:775)
> cumulative,
> > > hi,
> to
> "unhandled
> > > Balaji...
| Re: Unhandled exception caught in event loop. [message #18742 is a reply to message #18332] |
Fri, 30 August 2002 13:27  |
> !STACK 0
> at
> 453)
Why does the EditorManager think that your Editor is external? I assume
this means some type of native App?
You should be able to use the debugger to create a breakpoint at the line
above, or at any ClassCastException.
FUDForum. Page generated in 0.04673 seconds
