Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » problem xotcl
problem xotcl [message #18152] Sun, 18 November 2007 13:49 Go to next message
Originally posted by: manfred_stelzhammer.aon.at
I downloaded and installed eclipse and the "dynamic languages toolkit
extensions" with the XOTCL IDE extension.
I'll use eclipse with xotcl.
But if I start eclipse I get an error:
Error creating the view
An error occurred while automatically activating bundle
org.eclipse.dltk.ui (152).
I installed on linux "kubuntu 7.10".
JRE from www.java.com version 6 update 3
I installed on /usr/eclipse.
The owner and group is root and the rights are 777 on /usr/eclipse and all
subdirectiories.
I downloaded the two files to /usr and extracted the files.
Then i started eclipse.
What do I wrong?
Manfred
Re: problem xotcl [message #18207 is a reply to message #18152] Tue, 20 November 2007 03:30 Go to previous messageGo to next message
Hi Manfred,
Please could you specify Eclipse and DLTK versions.
And full text of error.
Thanks, Andrei.
> Hi I downloaded and installed eclipse and the "dynamic languages toolkit
> all subdirectiories.
> What do I wrong?
> Regards
> Manfred
Re: problem xotcl [message #18242 is a reply to message #18207] Tue, 20 November 2007 03:54 Go to previous messageGo to next message
Originally posted by: manfred.antispam.at
Andrei Sobolev wrote:
> Hi Manfred,
> Thanks, Andrei.
I installed the latest version.
Eclipse SDK
Version: 3.3.1.1
Build ID: M-20071023-1652
DLTK
dltk-xotcl-tcl-core-sdk-S-1.0M3-200711091536-incubation.zip
ERROR TEXT
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(libgcj.so.81)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:252)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:248)
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:231)
org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:841)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:606)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1405)
org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:939)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3296)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2974)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:801)
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at java.lang.reflect.Method.invoke(libgcj.so.81)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Caused by: org.osgi.framework.BundleException: Exception in
org.eclipse.dltk.ui.DLTKUIPlugin.start() of bundle org.eclipse.dltk.ui.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1018)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
...55 more
Caused by: java.lang.NoClassDefFoundError:
org.eclipse.dltk.internal.launching.DLTKLaunchingPlugin
at org.eclipse.dltk.ui.DLTKUIPlugin.start(DLTKUIPlugin.java:140 )
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
at java.security.AccessController.doPrivileged(libgcj.so.81)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
...60 more
Thank's
Manfred
Re: problem xotcl [message #18275 is a reply to message #18242] Sat, 24 November 2007 13:17 Go to previous message
Now I solved the problem
I start eclipse with the parameter "-vm <path to java vm>"
Now it works like expected
Manfred
Previous Topic:Semantic Highlighting and ANTLR Parser
Next Topic:Create Folder in Project with Wizard
Current Time: Sun Nov 30 01:29:11 EST 2025
Powered by FUDForum. Page generated in 0.03880 seconds
