Home » Modeling » GMF (Graphical Modeling Framework) » Alternative types of top node elements
Alternative types of top node elements [message #189965] Thu, 29 May 2008 05:33 Go to next message
Hi there,
I want to do something very simple:
I have two objects in my domain model: A State and a CompartmentState,
where the CompartmentState extends the State. Now the CompartmentState
aggregates States in a "myStates" relation, hence it can contain States
and CompartmentStates recursively, modeling hierarchy.
The diagram extends CompartmentState, hence it can contain both types.
How do I set this up correctly in the mapping?
1. I cannot create two TopNodeReference for both State and
CompositeState, because I have only one aggregation "myStates". Hence I
get an error message if I choose the same Containment Feature:
"Phantom nodes that are not targeted by a link mapping exist".
2. I cannot create a single TopNodeReference to State (which gets
extended by CompartmentState), because only the latter has a Child
Reference to "myStates".
3. Next try would be to create a second aggregation from
CompartmentState to CompartmentState recursively to get two distinct
aggregations, but this is not exactly what I want...
How to do it?
Hauke
Re: Alternative types of top node elements [message #190050 is a reply to message #189965] Thu, 29 May 2008 07:57 Go to previous messageGo to next message
Hello Hauke,
This is a correct way to solve this problem - you can create two TopNodeReferences
with the same containment feature specified and different NodeMappings inside.
This error should be visible only if you have TopNodeReference without containment
feature specified.
Alex Shatalin
Re: Alternative types of top node elements [message #190375 is a reply to message #190050] Sat, 31 May 2008 08:39 Go to previous messageGo to next message
> TopNodeReferences with the same containment feature specified and
Hey Alex, thanks, works now on the diagram level. Unfortunately within
the Compartment I can only add States but not CompositeStates although I
think I got the mapping right:
Mapping
- Top Node Reference <node:ComppositeState/CompositeState>
- - Node Mapping <CompositeState/CompositeState>
- - - Feature Label Mapping false
- - - Child Reference <nodes:State/Node>
- - - - Node Mapping <State/Node>
- - - - - Feature Label Mapping false
- - - Child Reference <nodes:CompositeState/CompositeState>
- - - - Node Mapping <CompositeState/CompositeState>
- - - Compartment Mapping <CompositeStateCompartment>
-> Children: both prev defined Child References
- Top Node Reference <nodes:State/Node>
Adding a CompartmentState to a CompartmentState gives the following
exception which I cannot decipher...
org.eclipse.core.commands.ExecutionException: While executing the
operation, an exception occurred
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:519)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:205)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:168)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:155)
at org.eclipse.gef.tools.AbstractTool.executeCommand(AbstractTo ol.java:399)
org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(Abs tractTool.java:411)
org.eclipse.gmf.runtime.diagram.ui.tools.CreationTool.perfor mCreation(CreationTool.java:133)
at org.eclipse.gef.tools.CreationTool.handleButtonUp(CreationTo ol.java:178)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java :1064)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:259)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Released(DomainEventDispatcher.java:374)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(Li ghtweightSystem.java:538)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:206)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1145)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3335)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2982)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2392)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2356)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 22)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:474)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:469)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:362)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 564)
at org.eclipse.equinox.launcher.Main.run(Main.java:1251)
at org.eclipse.equinox.launcher.Main.main(Main.java:1227)
Caused by: org.eclipse.jface.util.Assert$AssertionFailedException: null
argument;failed to create a view
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:153)
org.eclipse.gmf.runtime.diagram.ui.commands.CreateCommand.do ExecuteWithResult(CreateCommand.java:99)
org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand.doExecute(AbstractTransactionalCommand.ja va:246)
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:157)
org.eclipse.gmf.runtime.common.core.command.CompositeCommand .doExecuteWithResult(CompositeCommand.java:403)
org.eclipse.gmf.runtime.common.core.command.AbstractCommand. execute(AbstractCommand.java:134)
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
... 37 more
Re: Alternative types of top node elements [message #190510 is a reply to message #190375] Mon, 02 June 2008 07:27 Go to previous messageGo to next message
Hello Hauke,
Do you have corresponding constraints specified in mapping file? Something
like "not self.oclIsTypeOf(CompartmentState)" for AState mappings.
Alex Shatalin
Re: Alternative types of top node elements [message #190868 is a reply to message #190510] Wed, 04 June 2008 03:08 Go to previous messageGo to next message
Hi Alex,
> Something like "not self.oclIsTypeOf(CompartmentState)" for AState
> mappings.
No, there are no constraints at all. That's why I'm a bit confused about
it here...
Hauke
Re: Alternative types of top node elements [message #190963 is a reply to message #190868] Wed, 04 June 2008 08:46 Go to previous messageGo to next message
Hello Hauke,
> about it here...
So, I suggest you to add these constraints - GMF can mistakenly recognize
CompartmentState as a State (it actually is instance of State...) So, I suggest
you to prevent framework from doing it by addition proper constraint (see
my prev. message).
Alex Shatalin
Re: Alternative types of top node elements [message #191106 is a reply to message #190963] Wed, 04 June 2008 14:19 Go to previous messageGo to next message
Hi Alex, thanks a lot for your hints so far!
>>> AState mappings.
>> about it here...
> recognize CompartmentState as a State (it actually is instance of
> State...) So, I suggest you to prevent framework from doing it by
> addition proper constraint (see my prev. message).
ah, okay, got what you meant. I added that ocl constraint and: Yes, I
now can add as many hierarchichal CompositeStates as I want recursively
into each other. Yipiie!
BUT: Now I cannot add a simple "State" anymore, neither to the root
element nor to a CompositeState. I get same exception for the States now
as I got for CompositeStates before. Anything else I need to constrain?
Hauke
Re: Alternative types of top node elements [message #191255 is a reply to message #191106] Thu, 05 June 2008 13:07 Go to previous messageGo to next message
Hello Hauke,
It's ratehr strange - looks like incorrect OCL constraint.. Can you debug
generated ???VisualIDRegistry to see why corresponding condition was not
satisfied for simple "State"?
Alex Shatalin
Re: Alternative types of top node elements [message #191590 is a reply to message #191255] Mon, 09 June 2008 03:58 Go to previous message
> debug generated ???VisualIDRegistry to see why corresponding condition
> was not satisfied for simple "State"?
Hi Alex,
works now: debugged it and found some syntax error in the OCL
expression. With the correct expression it works now perfectly. Thanks a
lot for your time and help!
Hauke
Previous Topic:Tutorial using EMF and GMF
Next Topic:Multiple palettes in a single editor
Current Time: Mon Sep 15 02:28:05 EDT 2025
Powered by FUDForum. Page generated in 0.07945 seconds
