Home » Eclipse Projects » GEF » rotating a text label
rotating a text label [message #189897] Sun, 31 July 2005 16:11 Go to next message
I have labels positioned at the midpoint of my connections.
I would like to rotate the label/text to be parallel to the connection.
Is this possible with finite effort?
thanks,
Benedict
Re: rotating a text label [message #191612 is a reply to message #189897] Wed, 10 August 2005 13:25 Go to previous message
I have done this just for fun in my workspace. I did it using a rotatable
decoration where you set the anchor point and control point. The only
tricky part is trying to figure out the bounds required by the rotated text.
Note that Strings are rendered the same size when rotated, so you may need
to measure them on a rotated GC.
See Graphics.rotate(float)
"benedict heal" <bh@benedictheal.com> wrote in message
news:dcjb9k$uav$1@news.eclipse.org...
> thanks,
> Benedict
Previous Topic:Design issue related to EditParts
Next Topic:Commands in the GEF text editing sample are not redoable
Current Time: Sat Nov 08 06:18:35 EST 2025
Powered by FUDForum. Page generated in 0.05221 seconds
