Home » Language IDEs » Java Development Tools (JDT) » Strange eclipse compilation error
Strange eclipse compilation error [message #189836] Thu, 16 December 2004 15:35 Go to next message
Originally posted by: cao.mobilematrix.net
I'm using eclipse 3.0.1 build 200409161125 with latest JDT etc. I got
strange compilation errors only when extending PrintWriter and
implementing Runnable at the same time.
here is the sample code
import java.io.OutputStreamWriter;
import java.io.PrintWriter;
public class Test extends PrintWriter implements Runnable {
public Test(OutputStreamWriter out, boolean flag) {
super(out, flag);
public void run() {
here is the error:
The return type is incompatible with Writer.append(char),
PrintWriter.append(char)
When I use ant to compile, I have no problem at all. Did anyone see this
before? Could this be a bug in eclipse or that code does have something
wrong?
Any hint would be highly appreciated!
Cao
PS: my os = windows xp home with sp2;
my java = 1.5.0 build 1.5.0-b64
Re: Strange eclipse compilation error [message #189857 is a reply to message #189836] Thu, 16 December 2004 17:24 Go to previous message
> wrong?
If you use 1.5 libraries, compile using the compliance 1.5 or switch to
1.4 librairies.
Olivier
Previous Topic:Code templates using ${line_selection}
Next Topic:Cannot step in debugged apps
Current Time: Wed Nov 12 13:48:31 EST 2025
Powered by FUDForum. Page generated in 0.03545 seconds
