EOL [message #17961] |
Mon, 11 May 2009 08:25  |
Originally posted by: arendt.mathematik.uni-marburg.de
Hi!
I'm new in Epsilon and I'm doing the examples from the "EpsilonBook".
But there is a first error when running the example on page 51:
"Type 'Uml!Class' not found"
What went wrong?
Thorsten
Re: EOL [message #17986 is a reply to message #17973] |
Mon, 11 May 2009 09:07  |
Hi Dimitris!
Thank you very much for your help. That was my mistake...
Thorsten
Dimitris Kolovos schrieb:
> Hi Thorsten,
> I suspect it's just that you haven't specified a model named UML in the
> "Models" tab of the launch configuration. In
> http://www.eclipse.org/gmt/epsilon/cinema/BuildOOInstance_pa rt2.htm
> (accessible under http://www.eclipse.org/gmt/epsilon/cinema) there is an
> example of adding a model to an EOL launch configuration.
> In your case, you should create a UML model and then add it to the
> launch configuration using the UML2 metamodel uri:
> http://www.eclipse.org/uml2/2.1.0/UML
> Cheers,
> Dimitris
> Thorsten Arendt wrote:
>> Hi!
>> What went wrong?
>> Thorsten
Re: EOL [message #568062 is a reply to message #17973] |
Hi Dimitris!
Thorsten
> Hi Thorsten,
> Cheers,
> Dimitris
>> Hi!
>> What went wrong?
>> Thorsten
FUDForum. Page generated in 0.10398 seconds
