Eclipse IDE - CDT - Cygwin - Make problems [message #189047] |
Tue, 10 April 2007 03:10 |
Originally posted by: Marco.Benedetti.cae.it
Hi All, I'm using Eclipse 3.2.1 + CDT 3.1.2 + GNU ToolChain for ARM Target
+ GNU Make 3.75. on a WinXP O.S. with Cygwin.
After some hours of hard work i have been able to create a project for
STR912
usign Eclipse IDE. The project is a managed make one.
I'm able to start build process, but something doesn't work during
building.
After a short analisys i found that the makefiles generator inserts the
'\' char at the end of lines (linux like). Unfortunately commands in
makefiles are executed under WinXp (the sh command isn't called) and not
under bash shell. As a result i see the following logs on the Console
window:
**** Genera della configurazione Release per il progetto ProvaEclipseStr9
make -k all 'File di generazione: ../Prova1/STR9Library/91x_it.c'
'Richiamo: GNU ARM C Compiler'
arm-elf-gcc -mcpu=arm9e
-I"C:/Source/WorkSpace/ProvaEclipseStr9/Prova1/Application"
-I"C:/Source/WorkSpace/ProvaEclipseStr9/Prova1/HwAbstrLayer "
-I"C:/Source/WorkSpace/ProvaEclipseStr9/Prova1/Str9Library"
-I"C:/Programmi/GNUARM/arm-elf/include"
-I"C:/Programmi/GNUARM/arm-elf/sys-include"
-I"C:/Programmi/GNUARM/include" -O3 -c -fmessage-length=0
-o"Prova1/STR9Library/91x_it.o" "../Prova1/STR9Library/91x_it.c" && \
echo -n 'Prova1/STR9Library/91x_it.d' Prova1/STR9Library/ >
'Prova1/STR9Library/91x_it.d' && \
arm-elf-gcc -MM -MG -P -w -mcpu=arm9e
"../Prova1/STR9Library/91x_it.c" >> 'Prova1/STR9Library/91x_it.d'
"\" non riconosciuto come comando interno o esterno,
un programma eseguibile o un file batch.
Impossibile trovare il percorso specificato.
'Generazione terminata: ../Prova1/STR9Library/91x_it.c'
The last 5 lines of the log says:
"\" isn't an internal or external command, an executable file or a batch
file.
Unable to find the specified path.
'Build process finisheds: ../Prova1/STR9Library/91x_it.c'
Can someone help me to solve this problem.
Marco Benedetti
FUDForum. Page generated in 0.03109 seconds
