Home » Eclipse Projects » Plugin Development Environment (PDE) » How to save information between the sessions of Eclipse?
How to save information between the sessions of Eclipse? [message #17954] Wed, 27 August 2008 07:26 Go to next message
Good day! I've developed plugin. Now I want to save some data between the
sessions of Eclipse (for example, a String or int variable). How to do
this in a proper way?
Thanks.
Re: How to save information between the sessions of Eclipse? [message #18023 is a reply to message #17954] Thu, 28 August 2008 02:28 Go to previous messageGo to next message
Originally posted by: prashanto.chatterjee.gmail.com
Have a look at the ISaveParticipant mechanism. There is a good deal of help
avaialable on that.
You may also want to read the article:
http://www.eclipse.org/articles/Article-Resource-deltas/reso urce-deltas.html
"Drug Vignera" <DrugVignera@mail.ru> wrote in message
news:81b157f17a2542fa29be51b72bd55c4b$1@www.eclipse.org...
> Thanks.
IMHO, this is not appropriate. [message #18034 is a reply to message #18023] Thu, 28 August 2008 10:12 Go to previous messageGo to next message
I mean, where to save my data? Into eclipse/plugins/myfile.ini? Into
eclipse/plugins/myplugin/myfile.ini? Is there some common default place?
(For example, something like eclipse/configuration/config.ini or
workspace/.metadata/config.ini.)
When my plugin starts to work, it must read this data and then save new
one.
Re: How to save information between the sessions of Eclipse? [message #18047 is a reply to message #17954] Thu, 28 August 2008 12:13 Go to previous messageGo to next message
Originally posted by: tom.seidel.spiritlink.de
See http://www.eclipse.org/articles/Article-Preferences/preferen ces.htm
Tom
> the sessions of Eclipse (for example, a String or int variable). How to
> do this in a proper way?
> Thanks.
Re: How to save information between the sessions of Eclipse? [message #18060 is a reply to message #17954] Thu, 28 August 2008 13:57 Go to previous messageGo to next message
OSGi allows a bundle to store data in its private data area, which is
accessed via the BundleContext API getDataFile(String). This approach is
nice since it keeps the data private to the bundle, and the data goes
away when you uninstall the bundle.
http://www.osgi.org/javadoc/r4/org/osgi/framework/BundleCont ext.html#getDataFile(java.lang.String)
> Thanks.
Re: How to save information between the sessions of Eclipse? [message #18767 is a reply to message #18047] Mon, 01 September 2008 08:09 Go to previous message
Thanks.
The answer to my question is:
Activator.getDefault().getPreferenceStore().getString("my_key ");
Activator.getDefault().getPreferenceStore().setValue("my_key ", "my_value");
Re: How to save information between the sessions of Eclipse? [message #577608 is a reply to message #17954] Thu, 28 August 2008 02:28 Go to previous message
avaialable on that.
> Thanks.
IMHO, this is not appropriate. [message #577621 is a reply to message #18023] Thu, 28 August 2008 10:12 Go to previous message
one.
Re: How to save information between the sessions of Eclipse? [message #577671 is a reply to message #17954] Thu, 28 August 2008 12:13 Go to previous message
Tom
> Thanks.
Re: How to save information between the sessions of Eclipse? [message #577686 is a reply to message #17954] Thu, 28 August 2008 13:57 Go to previous message
> Thanks.
Re: How to save information between the sessions of Eclipse? [message #577959 is a reply to message #18047] Mon, 01 September 2008 08:09 Go to previous message
Thanks.
Previous Topic:Unwanted plugin/bundle getting deployed (jetty 1.1.0 ticked, jetty 2.0.0 NOT, both deployed)
Next Topic:Queries on Headless PDE Build
Current Time: Fri Nov 21 14:24:01 EST 2025
Powered by FUDForum. Page generated in 0.25119 seconds
