Home » Eclipse Projects » GEF » opening a second editor
opening a second editor [message #188646] Thu, 21 July 2005 10:23 Go to next message
Originally posted by: smoreno.business-innovations.biz
Hi:
by default eclipse allows only one editor for the same file
what i want to do is open a second editor double clicking a figure from the
first editor
some sugestions?
Sergio Moreno
Re: opening a second editor [message #188699 is a reply to message #188646] Fri, 22 July 2005 10:28 Go to previous messageGo to next message
There are several approaches to solve this problem.
I have recently developed an editor(for example EditorFirst). When
clicking a figure(for example Figure1) from EditorFirst a second gef
editor(EditorSecond) opens and I edit Figure1 in EditorSecond.
The input I pass to EditorSecond contains Figure1.
Opening the editor is not very difficult.
I have an ui action called "Edit Figure1".
In the run method of the action I execute this:
IWorkbenchWindow window =
getWorkbenchPart().getSite().getWorkbenchWindow();
window.getActivePage().openEditor(input,"EditorSecondID");
In the getAdapter() method of the input of EditorSecond I get Figure1 and
edit it using EditorSecond.
In eclipse the input of an editor does NOT have to be a file. So this
gives you freedom (and much flexability) with one editor to edit various
things. Not just files.
There is also another approache. - Multipage editor.
I have also worked on a multipage editor. The first page is a GEF editor,
and the second is page are just some jface controls.
Maybe it will be better to have a multipage editor.
kiril
Sergio Moreno wrote:
> Hi
> Hi:
> first editor
> some sugestions?
Re: opening a second editor [message #188867 is a reply to message #188699] Fri, 22 July 2005 15:28 Go to previous messageGo to next message
Thanks for the answer
I have created the action that opens the new editor and activates only when
the figure is selected
but its not so clear to me the getAdapter method part of your answer
Do I have to create a implementation of IEditorInput passing the editpart of
the selected figure?
it would'nt be a problem that this editpart is asociated with one figure
that is not a layer (or a panel)?
it will be great if you have some links to a examples where this is
implemented.....
"Kiril Mitov" <kiril_mitov@abv.bg> escribi
Re: opening a second editor [message #188898 is a reply to message #188646] Fri, 22 July 2005 17:53 Go to previous message
Originally posted by: sunil_kamath.nohotspammail.com
"Sergio Moreno" <smoreno@business-innovations.biz> wrote in message
news:dbp07j$j1q$2@news.eclipse.org...
> Hi
> Hi:
> the
> first editor
Eclipse 3.1 allows you to open multiple editors for the same file.
Sunil
Previous Topic:Refreshing Images
Next Topic:A Dash Line is Possible?
Current Time: Thu Jul 17 20:51:36 EDT 2025
Powered by FUDForum. Page generated in 0.71162 seconds
