Sorting 'Qualifiers' section in "Open type" dialog [message #188425] |
Fri, 03 December 2004 08:58 |
Originally posted by: Jeevan.somewhere.com
I am using eclipse 3.0.1.and facing a problem with the 'Open Type' dialog.
In my build process using Ant I create a JAR of the project in its
classpath.
In the 'Open Type' dialog when I put in the name of any particular java
object, I see the list of all objects matching the name (with the first
one selected) --> Perfectly OK
In the bottom portion of the dialog (Qualifier) I see 2 options
The JAR file in which the object exists and
the source folder in which it is present.
The problem is with the sorting of the Qualifier section -
Why does the JAR come first and the java\src directory after that?
thx
g1
FUDForum. Page generated in 0.26291 seconds
