Home » Language IDEs » C / C++ IDE (CDT) » CDT 4.0.0 M5 Variables window kills debugging -- ideas?
CDT 4.0.0 M5 Variables window kills debugging -- ideas? [message #188196] Wed, 28 March 2007 03:13 Go to next message
Originally posted by: noreally.notaserver.com
Folks:
Anyone have any clue whether this is work-around-able?
Eclipse 3.3M5eh with CDT 4.0.0 M5 linux (Centos 4)
This is a "Standard Make" project.
I can single step through my project, but if I open the Variables window, on
the next step the debugger appears to hang (though I can terminate the app
with the terminate button).
In the console window I get the error output shown below.
FWIW, if I terminate the app, close the Variables window, and then start
debugging again, no problem.
Graham
[graham@gwlinux eclipse_3.3M5eh]$ ./eclipse_launch.bash
Exception in thread "MI Event Thread" java.lang.StackOverflowError
at java.util.Hashtable.get(Unknown Source)
at java.util.Properties.getProperty(Unknown Source)
at java.lang.System.getProperty(Unknown Source)
org.eclipse.cdt.debug.mi.core.output.MIConst.isoC(MIConst.ja va:94)
org.eclipse.cdt.debug.mi.core.output.MIConst.getString(MICon st.java:50)
org.eclipse.cdt.debug.mi.core.output.MIStreamRecord.getStrin g(MIStreamRecord.java:29)
org.eclipse.cdt.debug.mi.core.command.Command.throwMIExcepti on(Command.java:95)
org.eclipse.cdt.debug.mi.core.command.MIVarCreate.getMIInfo( MIVarCreate.java:72)
org.eclipse.cdt.debug.mi.core.command.MIVarCreate.getMIVarCr eateInfo(MIVarCreate.java:63)
org.eclipse.cdt.debug.mi.core.cdi.model.Variable.getMIVar(Va riable.java:131)
org.eclipse.cdt.debug.mi.core.cdi.VariableManager.update(Var iableManager.java:662)
org.eclipse.cdt.debug.mi.core.cdi.VariableManager.update(Var iableManager.java:682)
[... 100's of repetitions of this last line...]
Re: CDT 4.0.0 M5 Variables window kills debugging -- ideas? [message #188373 is a reply to message #188196] Wed, 28 March 2007 23:06 Go to previous messageGo to next message
Additional info:
The project in which the problems were seen is reasonably "large-ish":
-- Two projects (ie: project for building an app has to include another
project to incorporate many include files and to link in a large library).
-- Automake/configure apparatus.
-- It was using -O2 optimization
I've now reconfigured to use no optimization. The variables window now seems
to operate OK (and there are no messages in the console window).
Bottom line -- the reported symptoms appear to relate to optimization, and
many variables not being available for the Variables window to query.
Graham
Re: CDT 4.0.0 M5 Variables window kills debugging -- ideas? [message #188386 is a reply to message #188373] Thu, 29 March 2007 03:07 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
Graham,
Are you aware that 4.0M5 is not released? It primarily aimed at (very) early
adopters who are developing new features/plugins for 4.0. As such, it is missing
features, and it is known to be buggy (debug is one area that is in flux). This
is to be expected as it is not for release until June this year. If you want a
stable release, you should be using Eclipse 3.2.2 and CDT 3.1.2.
However, I am sure the developers would be interested in a bug report. Please
report at: https://bugs.eclipse.org/bugs/
Derek
Graham Wideman wrote:
> Additional info:
> Graham
Re: CDT 4.0.0 M5 Variables window kills debugging -- ideas? [message #188418 is a reply to message #188386] Thu, 29 March 2007 04:52 Go to previous message
Originally posted by: Jens.Seidel.imkf.tu-freiberg.de
> early adopters who are developing new features/plugins for 4.0. As such,
> it is missing features, and it is known to be buggy (debug is one area
> that is in flux). This is to be expected as it is not for release until
> June this year. If you want a stable release, you should be using Eclipse
It is already well suited for testing and developers reply to and fix bugs
very fast.
> Please report at: https://bugs.eclipse.org/bugs/
I noticed the same problem (but my initial posting to your one got lost).
Once a variable which is optimized away is selected the gdb console prints
many duplicated messages. Please post here your bug number so that I can
add myself to CC:
Jens
Previous Topic:PostBuildStep - macro resolver
Next Topic:Comile Errors
Current Time: Sat Nov 08 18:07:10 EST 2025
Powered by FUDForum. Page generated in 0.23753 seconds
