Home » Language IDEs » Java Development Tools (JDT) » needs code snippet for ICompilationUnit javadoc promise
needs code snippet for ICompilationUnit javadoc promise [message #188187] Thu, 02 December 2004 10:48 Go to next message
Originally posted by: edoardoATenigmatecDOTnet.no.spam
I previously posted on the same problem but can't find an answer.
I'd need to see a code snippet that does what the following javadox
promises : creating an ICompilationUnit on an not-yet-existing one
my attempts so far fail - to me it seems I need to create the resource
BEFORE I commit.
TIA,
Edo
package org.eclipse.jdt.core;
public interface ICompilationUnit ...
* Since 2.1, a working copy can be created on a not-yet existing
compilation
* unit. In particular, such a working copy can then be committed in
order to create
* the corresponding compilation unit.
void commitWorkingCopy(boolean force, IProgressMonitor monitor) throws
JavaModelException;
Re: needs code snippet for ICompilationUnit javadoc promise [message #188392 is a reply to message #188187] Fri, 03 December 2004 07:12 Go to previous messageGo to next message
You can have a look at the Java model test:
org.eclipse.jdt.core.tests.model.WorkingCopyTests#testNonExi stingCu().
HTH,
Jerome
"Edoardo Comar" <edoardoATenigmatecDOTnet@no.spam> wrote in message
news:condg0$n3m$1@www.eclipse.org...
> Hi
> BEFORE I commit.
> TIA,
> Edo
> compilation
> order to create
> JavaModelException;
Re: needs code snippet for ICompilationUnit javadoc promise [message #188400 is a reply to message #188392] Fri, 03 December 2004 07:52 Go to previous messageGo to next message
Thanks Jerome!
can you confirm that there is currently no way to open an editor on such
a compilation unit ?
if you think it would be reasonable to implement such a request, I'll
enter it into bugzilla
My rationale is that my plugin provides an editor for a 'domain object'
which has some details implemented by java classes.
As long as the editor is dirty, ie manipulating a domain object in
memory, I would be happy to keep the ICompilationUnits in memory as well,
and commit (or discard them) all when the editor is saved (or closed
without saving, respectively).
Edo
> HTH,
> Jerome
>>Hi
>>BEFORE I commit.
>>TIA,
>>Edo
>>compilation
>>order to create
>>JavaModelException;
Re: needs code snippet for ICompilationUnit javadoc promise [message #188417 is a reply to message #188400] Fri, 03 December 2004 08:46 Go to previous messageGo to next message
I'm not in the editor business, but I would expect to be able to open an
editor on such a compilation unit.
What makes you say that it is not possible ? Do you get any exception when
attempting to open an editor on such a compilation unit ?
Jerome
news:copnhk$ne7$1@www.eclipse.org...
> Thanks Jerome!
> Edo
> > HTH,
> > Jerome
> >>Hi
> >>BEFORE I commit.
> >>TIA,
> >>Edo
> >>compilation
> >>order to create
> >>JavaModelException;
Re: needs code snippet for ICompilationUnit javadoc promise [message #188450 is a reply to message #188417] Fri, 03 December 2004 10:11 Go to previous message
--------------000605070300070901080803
The exception is ... "File does not exist" (surprise :-)
here is attached an action that you can declare in an action set and try
I'm submitting the issue to bugzilla
Edo
> Jerome
>>Thanks Jerome!
>>Edo
>>>HTH,
>>>Jerome
>>>>Hi
>>>>BEFORE I commit.
>>>>TIA,
>>>>Edo
>>>>compilation
>>>>order to create
>>>>JavaModelException;
Content-Type: text/x-java;
name="TestActionSetAction2.java"
Content-Disposition: inline;
filename="TestActionSetAction2.java"
* @(#)$Id: TestActionSetAction2.java,v 1.2 2004/12/03 09:54:41 edoardo Exp $
* Confidential Licenced Materials of Enigmatec Corporation.
* Copyright Enigmatec Corporation @ 2004
package com.enigmatec.emsj.test.visualinspection;
import java.io.PrintWriter;
import java.io.StringWriter;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IResource;
import org.eclipse.core.runtime.IPath;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.jdt.core.ICompilationUnit;
import org.eclipse.jdt.core.JavaCore;
import org.eclipse.jdt.ui.JavaUI;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.dialogs.ErrorDialog;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.IWorkbenchWindowActionDelegate;
* It creates a new non existing Java ICompilationUnit working copy in the same package as the currently
* open java editor and then attempts to open an editor on it.
* <p>
* This action can be contributed by an action set.
* </p>
* <pre>
* <extension
point="org.eclipse.ui.actionSets">
<actionSet
label="TESTactionSet"
visible="true"
id="visualinspection.actionSets.ID">
<action
label="TASA2"
class=" com.enigmatec.emsj.test.visualinspection.TestActionSetAction 2 "
tooltip="actionSets Visual inspection test2"
toolbarPath="testpath"
id="visualinspection.actionSets.actionTEST.ID2">
</action>
</actionSet>
</extension>
* </pre>
* @author Edoardo Comar <edoardo.NOSPAM@NOSPAM.enigmatec.net>
public class TestActionSetAction2 implements IWorkbenchWindowActionDelegate {
private IWorkbenchWindow window;
private ISelection selection;
public TestActionSetAction2() {
super();
* the guts of the action
protected void runWithException(IAction action) throws Exception {
IEditorPart editorPart = getWorkbenchWindow().getActivePage().getActiveEditor();
if (editorPart == null) {
return;
IEditorInput editorInput = editorPart.getEditorInput();
IResource resource = (IResource) editorInput.getAdapter(IResource.class);
if (resource == null) {
return;
ICompilationUnit icu = JavaCore.createCompilationUnitFrom((IFile) resource);
if (icu == null) {
return;
IPath icuPath = icu.getPath();
IPath nonExistingCUPath = icuPath.removeLastSegments(1).addTrailingSeparator().append(
"Foo.java");
IFile nonExistingFile = resource.getWorkspace().getRoot().getFile(nonExistingCUPath) ;
System.out.println(nonExistingFile);
ICompilationUnit nonExistingCU = JavaCore.createCompilationUnitFrom(nonExistingFile);
ICompilationUnit workingCopy = nonExistingCU.getWorkingCopy(null);
workingCopy.getBuffer().setContents("public class Foo {\n }\n");
System.out.println(workingCopy);
JavaUI.openInEditor(workingCopy);
* (non-Javadoc)
* @see org.eclipse.ui.IActionDelegate#run(org.eclipse.jface.action. IAction)
public void run(IAction action) {
try {
runWithException(action);
} catch (Exception e) {
StringWriter sw = new StringWriter();
e.printStackTrace(new PrintWriter(sw));
String smallStackTrace = sw.toString().substring(0, Math.min(sw.toString().length(), 500));
ErrorDialog.openError(window.getShell(), "ERROR", e.getMessage(), new Status(IStatus.ERROR,
"your-plugin-id", IStatus.ERROR, smallStackTrace, e));
/* (non-Javadoc)
* @see org.eclipse.ui.IActionDelegate#selectionChanged(org.eclipse. jface.action.IAction, org.eclipse.jface.viewers.ISelection)
public void selectionChanged(IAction action, ISelection selection) {
this.selection = selection;
/* (non-Javadoc)
* @see org.eclipse.ui.IWorkbenchWindowActionDelegate#dispose()
public void dispose() {
window = null;
selection = null;
/* (non-Javadoc)
* @see org.eclipse.ui.IWorkbenchWindowActionDelegate#init(org.eclip se.ui.IWorkbenchWindow)
public void init(IWorkbenchWindow window) {
this.window = window;
protected IWorkbenchWindow getWorkbenchWindow() {
return window;
protected ISelection getSelection() {
return selection;
--------------000605070300070901080803--
Previous Topic:Writing JNI with JDT+CDT
Next Topic:AST to source
Current Time: Mon Jul 21 21:53:30 EDT 2025
Powered by FUDForum. Page generated in 0.06746 seconds
