Home » Eclipse Projects » Eclipse Platform » Adding Jars to a Plugin Project
Adding Jars to a Plugin Project [message #187997] Sun, 01 February 2004 16:54 Go to next message
Originally posted by: pcopeland.avoka.com
I'm just starting development on a plugin and a little unclear on how I
should add libary Jars to the plugin project (using Eclipse 3 -M6). I have
quite a large number of library jars that will be needed by the plugin. Do I
just copy these to the project directory then manually add them to
plugin.xml or is their a better approach?
Philip
Re: Adding Jars to a Plugin Project [message #188020 is a reply to message #187997] Sun, 01 February 2004 18:01 Go to previous message
Originally posted by: pascal_rapicault.yahoo.fr
You can copy them in any folder that will be shipped with your folder, but
you also need to declare them into the runtime section of your plugin.xml.
PaScaL
"Philip Copeland" <pcopeland@avoka.com> a
Previous Topic:Label background transparent
Next Topic:Testing hello world plug in visible= true
Current Time: Sun Nov 09 19:11:31 EST 2025
Powered by FUDForum. Page generated in 0.02859 seconds
