Home » Newcomers » Newcomers » Syntax for calling oracle store procedure from dataset
Syntax for calling oracle store procedure from dataset [message #187791] Fri, 12 January 2007 11:45 Go to next message
Originally posted by: TrinhKTran.yahoo.com
I am looking into BIRT 2.2 and I notice that we are able to use the oracle
store procedure in version 2.2 but I am having difficult to use it in the
data set query. Would someone be kindly let me know the syntax for using
the output parameter.
our procedure is using a refcursor. Below is the signature of the Store
Procedure
PROCEDURE p_test (
chflag VARCHAR2 DEFAULT 'C',
P_MIN IN NUMBER,
P_MAX IN NUMBER,
column_in IN VARCHAR2,
pc_test IN OUT Pkg_test.rc_datawindow
TYPE rc_datawindow IS REF CURSOR;
Trinh
Re: Syntax for calling oracle store procedure from dataset [message #187800 is a reply to message #187791] Fri, 12 January 2007 12:22 Go to previous message
Originally posted by: zx.us.ibm.com
Please try the BIRT newsgroups ;)
~ Chris
Previous Topic:removing "computing additional info" message
Next Topic:Adding external JDBC JAR to plug-in
Current Time: Mon Nov 17 11:26:23 EST 2025
Powered by FUDForum. Page generated in 0.29515 seconds
