| having install problems with VE [message #17817] |
Wed, 04 February 2004 20:46  |
Originally posted by: zeitgeist45'spammano'.hotmail.com
hi-
I have GEF and EMF installed, I put the necessary files into /plugins and /features, but VE won't run. Also, org.eclipse.jem and org.eclipse.ve are not showing up in feature details. If anyone can clue me into what else I need to do, that would be helpful. thanks
| Re: having install problems with VE [message #19359 is a reply to message #18352] |
Wed, 18 February 2004 09:04  |
Originally posted by: Aisling.Vasey.intec.co.za
I did a totally new install of the same versions of Eclipse M5, EMF, GEF
and VE and then only started Eclipse for the first time and now the
plug-ins are visible and working with no additional configurations
necessary.
Not sure why this is the case but it works now.
Aisling
Rachid Buamar wrote:
> "Aisling Vasey" <Aisling.Vasey@intec.co.za> schrieb im Newsbeitrag
> news:c0a1ht$ccr$1@eclipse.org...
> > Hi
> > I am having similar problems. I tried installing:
> > Eclipse SDK 3.0 M5
> > EMF 2.0.0 20031219_0637VL
> > GEF runtime I20040108 and then tried GEF SDK I20040108
> > and
> > VE runtime IM520040206 and also tried VE runtime IM520040209a
> > OS is XP.
> > None of the plug-ins are visible in the feature window.
> I had similar problems. I solved the problems by changing the name of the
> folder where i installed eclipse.
> It seems thats Eclipse 3.0 M5 etc registrates new features/ plugins only
> after the path of its own directory changes.
> This is strange but it solved the problem. I tried it several times. The
> log-file says nothing.
> I used the same versions and the same OS as Aisling Vasey (see above).
> Rachid Buamar
| Re: having install problems with VE [message #580274 is a reply to message #17817] |
Thu, 05 February 2004 08:58  |
Do you get any errors in the .log file that indicates missing plugins? or
anything else that might be relevant to the org.eclipse.jem and
org.eclipse.ve plugins?
Also... which driver did you try to install? The 0.5.0 driver is stable but
runs on Eclipse 2.1.2.
The latest build (N20040113) is a nightly build and is work in progress
based on Eclipse build 3.0M5. The GEF and EMF plugins must be the ones
specified for each build.
Regards....
Peter Walker
"SCase" <zeitgeist45'spammano'@hotmail.com> wrote in message
news:bvs75p$60t$1@eclipse.org...
> hi-
| Re: having install problems with VE [message #580595 is a reply to message #18149] |
Tue, 10 February 2004 02:34  |
Eclipse SDK 3.0 M5
and
OS is XP.
Rich Kulp wrote:
> Also, please add what version of VE, Eclipse, GEF, EMF and on what OS
> are you running?
| Re: having install problems with VE [message #580642 is a reply to message #18285] |
Tue, 10 February 2004 11:12  |
You may want to double check the plugin directories in Windows Explorer to
be sure the files were unzipped to the correct directories. The zip file
structure for Eclipse SDK is eclipse\... whereas the zip file structure for
all others (i.e. GEF, EMF, VE) is features\... and plugins\...
Regards...
Peter Walker
"Aisling Vasey" <Aisling.Vasey@intec.co.za> wrote in message
> Hi
> Eclipse SDK 3.0 M5
> and
> OS is XP.
> Thanks
> > are you running?
| Re: having install problems with VE [message #580661 is a reply to message #18285] |
Tue, 10 February 2004 12:00  |
Have you activated the plugins in your Product Configuration? In Eclipse
3.0 installing plugins isn't as straight forward as dropping the files
in the directory as it was in 2.x. Go to Help->Software Updates->Manage
Configuration. There should be a link there for something like
"Activate new plugins" that will enable the new features.
- Jeff
Aisling Vasey wrote:
> Hi
> Eclipse SDK 3.0 M5
> and
> OS is XP.
| Re: having install problems with VE [message #580698 is a reply to message #18285] |
Tue, 10 February 2004 18:41  |
> Hi
> Eclipse SDK 3.0 M5
> and
> OS is XP.
Rachid Buamar
| Re: having install problems with VE [message #581395 is a reply to message #18352] |
necessary.
Aisling
> > Hi
> > Eclipse SDK 3.0 M5
> > and
> > OS is XP.
> Rachid Buamar
FUDForum. Page generated in 0.06165 seconds
