Home » Archived » M2M (model-to-model transformation) » [ATL] Safety of Model Transformations
| [ATL] Safety of Model Transformations [message #17750] |
Thu, 22 February 2007 18:11  |
Originally posted by: irbull.cs.uvic.ca
For the final part of my PhD I am creating a graphical editor that
generates ATL transformations. Because I am doing code generation, it
is possible to specify "bad" transformations. For example, someone
could easily assign a value from a String attribute to a Real or
Integer. While I do generate toReal(), i could have a problem if the
value is not really a Real (for example "hello".toReal() gives a Number
format Exception).
I am wondering if we can make ATL transformations "Safe". That is, they
won't die (or throw a whole bunch of exceptions), but rather just
continue along happily. In this case, they would just return NaN or
something.
Thoughts? Ideas?
cheers,
ian
| Re: [ATL] Safety of Model Transformations [message #18439 is a reply to message #17750] |
Fri, 23 February 2007 01:12   |
Actually, ATL does continue well if there are problems, it just throws a
bunch of exceptions. Is there a way to suppress the errors / stack traces?
cheers,
ian
> format Exception).
> something.
> Thoughts? Ideas?
> cheers,
> ian
| Re: [ATL] Safety of Model Transformations [message #18447 is a reply to message #18439] |
Fri, 23 February 2007 02:12   |
Hello Ian,
When you launch an ATL transformation programmatically, you specify a
Debugger (class org.atl.engine.vm.Debugger). The Debugger used in run
mode (i.e., org.atl.engine.vm.SimpleDebugger) only prints the stack
trace, whereas the Debugger used in debug mode (i.e.,
org.atl.engine.vm.NetworkDebugger) stops the execution an notifies the
debugger (e.g., Eclipse) using a TCP connection.
If you write your own Debugger class, you can simply ignore the errors.
It is, for instance, possible to extend org.atl.engine.vm.SimpleDebugger
and redefine the error(StackFrame frame, String msg, Exception e)
method, so that it does nothing special when an error occurs.
Alternatively, you may want to remember the errors and display them in a
different way.
Frédéric Jouault
> cheers,
> ian
>> Number format Exception).
>> they won't die (or throw a whole bunch of exceptions), but rather just
>> something.
>> Thoughts? Ideas?
>> cheers,
>> ian
| Re: [ATL] Safety of Model Transformations [message #18519 is a reply to message #18447] |
Fri, 23 February 2007 10:44   |
Ah... Thanks a lot.
You rock!
p.s. are the ATL crew going to EclipseCon?
- ian
Frédéric Jouault wrote:
> Hello Ian,
> different way.
> Frédéric Jouault
>> a bunch of exceptions. Is there a way to suppress the errors / stack
>> traces?
>> cheers,
>> ian
>>> it is possible to specify "bad" transformations. For example,
>>> someone could easily assign a value from a String attribute to a Real
>>> or Integer. While I do generate toReal(), i could have a problem if
>>> the value is not really a Real (for example "hello".toReal() gives a
>>> just continue along happily. In this case, they would just return
>>> NaN or something.
>>> Thoughts? Ideas?
>>> cheers,
>>> ian
Current Time: Wed Nov 05 20:54:07 EST 2025
Powered by FUDForum. Page generated in 0.05041 seconds
