Home » Eclipse Projects » SWTBot » CONSECUTIVES TEST
CONSECUTIVES TEST [message #17650] Mon, 26 January 2009 12:44 Go to next message
I am trying to test a plugin for eclipse. I have got a junit test case
with several methods (or test case). I want to test all but when a method
is tested, the following method continues and does not reset the
application.
Can I test all tests in a single run?
Thanks and regards.
Luis Miguel
Re: CONSECUTIVES TEST [message #17663 is a reply to message #17650] Mon, 26 January 2009 22:19 Go to previous message
Luis,
JUnit provides for setUp() and tearDown() methods, that allow you to
setup and clean up before each test case executes. That is probably what
you're looking for.
The JUnit site will have more information and examples on this:
http://junit.sourceforge.net/doc/testinfected/testing.htm
-- Ketan
On 26/1/09 23:14, Luis Miguel wrote:
> Hello,
> method is tested, the following method continues and does not reset the
> application.
> Thanks and regards.
> Luis Miguel
Previous Topic:Finding n-th widget of any type
Next Topic:widgetWithId(String) -> widgetWithId(Object)
Current Time: Thu Nov 06 06:06:31 EST 2025
Powered by FUDForum. Page generated in 0.02985 seconds
