Home » Archived » BIRT » MS SQL
MS SQL [message #17614] Fri, 11 March 2005 09:35 Go to next message
hello
I have a problem using MS SQL database (and driver)
it simply doesn't work
I create simple report using MS SQL datasource - no data are displayed
when I create the same simple report using sample MS Access database - it
works fine
in both cases I do the same steps
I've tried both M1 and the latest nightly build - doesn't work
have anybody had the same problem ? - please help!
Artur
Re: MS SQL [message #17640 is a reply to message #17614] Fri, 11 March 2005 14:19 Go to previous messageGo to next message
Originally posted by: mbatchelor.no_s_p_a_m.pentaho.com
This has to do with bugzilla bug 86314.
"Artur" <artekzx@o2.pl> wrote in message
news:d0saei$3b2$1@www.eclipse.org...
> hello
> works fine
> Artur
Re: MS SQL [message #17694 is a reply to message #17640] Fri, 11 March 2005 14:22 Go to previous message
Hi Marc, Arthur
The issue has been fixed in the current source.
Can you please verify it and let us know whether the problem still
happens for you.
With the jtds driver for MS SQL things seem to work correctly.
If it still doesn't work for you can you update the bugzilla entry with
details about the driver you used.
Roshan
>>hello
>>works fine
>>Artur
Previous Topic:RCP Application and report viewer
Next Topic:Page Number - Autotext
Current Time: Tue Nov 04 23:12:46 EST 2025
Powered by FUDForum. Page generated in 0.03409 seconds
