Home » Eclipse Projects » Eclipse Platform » Missing some API references in Eclipse Help
Missing some API references in Eclipse Help [message #17591] Sat, 26 April 2003 22:35 Go to next message
Originally posted by: milanst.ptt.yu
I downloaded eclipse source build and successfully built Eclipse 2.1 on
Windows XP.
But I am missing some API references (like JDT, PDE) in Eclipse Help window.
It states that these documents have not been installed.
I have also Eclipse 2.0 version (this was binary download) and there are no
missing APIs in 2.0.
How can I fix this? (unless this is how it is supposed to happen)
Milan
Re: Missing some API references in Eclipse Help [message #17604 is a reply to message #17591] Sat, 26 April 2003 23:01 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
Is it possible you downloaded the "Platform Runtime Binary" version instead
of the "Eclipse SDK" version? The former does not include the JDT and PDE.
The Eclipse SDK is much larger (about 65MB last time I checked for the
Windows version) but it does include those.
Ed Burnette, co-author Eclipse in Action (www.manning.com)
"Milan Stanojevic" <milanst@ptt.yu> wrote in message
news:b8ffmc$fjc$1@rogue.oti.com...
> Windows XP.
window.
no
> Milan
Re: Missing some API references in Eclipse Help [message #17691 is a reply to message #17604] Sun, 27 April 2003 14:56 Go to previous messageGo to next message
No, I downloaded source version of Eclipse SDK.
"Ed Burnette" <ed.burnette@REMOVE.THIS.sas.com> wrote in message
news:b8fh6s$gda$1@rogue.oti.com...
instead
> > Windows XP.
> window.
> no
> > Milan
Re: Missing some API references in Eclipse Help [message #17728 is a reply to message #17591] Sun, 27 April 2003 16:12 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
You downloaded one of the "eclipse-sourceBuild" zips, right?
I don't know why the help sections aren't there, since I never do that, but
I'm sure others do.
I suggest you repost your question under the subject "Help sections missing
in eclipse-sourceBuild" so people won't try to answer you assuming you
downloaded one of the "eclipse-SDK", etc. builds
Bob
> Windows XP.
window.
no
> Milan
Re: Missing some API references in Eclipse Help [message #17737 is a reply to message #17691] Sun, 27 April 2003 15:57 Go to previous messageGo to next message
Originally posted by: muelleimer.usenet.katzien.de
>> > window.
Easy explanation: They aren't build normally.
You need to add something to your build.xml. For debian packages
there is a patch. I've put it on my homepage:
www.katzien.de/debian/00-build.xml.patch
Here is the build script, which the latest debian packages use. If
you are on windows, this should be easy to addapt:
#!/bin/bash
# The path where source is unziped.
cd source-tree;
# first compile...
ant -buildfile build.xml run -Dos=linux -Dws=gtk ;
# and now we gather the plugins into zips
ant -buildfile build.xml gatherFeatureBinaries -Dos=linux -Dws=gtk ;
ant -buildfile build.xml gatherFeatureSources -Dos=linux -Dws=gtk ;
After that you can take the zips in source-tree/feature/*/*zip and
unzip them somewhere. After puting the starter files there as well,
you should have an 'almost the same as the zips' drop. I think the
releases also contain a Readme folder.
Jan
Re: Missing some API references in Eclipse Help [message #18469 is a reply to message #17737] Sun, 27 April 2003 21:00 Go to previous messageGo to next message
Thanx for the tips.
I am looking now at the build.xml files and it seems javadoc is having some
trouble.
There is a log file for javadoc and it states that there was an error. I
will look into it, and maybe try to port your patch.
Milan
"Jan Schulz" <muelleimer@usenet.katzien.de> wrote in message
news:slrnbaodgf.1up.muelleimer@snoopy.katzien.de...
> >> > window.
> #!/bin/bash
> cd source-tree;
> # first compile...
> Jan
Re: Missing some API references in Eclipse Help [message #18502 is a reply to message #17591] Mon, 28 April 2003 00:56 Go to previous message
It seams that the problem is related to javadoc tool.
I succesfully built Eclipse on Mandrake linux 9.1 with Sun JDK 1.4.1.
I have Sun JDK 1.4.0 on Windows so I will try to build Eclipse with Java
1.4.1. Maybe that will help.
> Windows XP.
window.
no
> Milan
Previous Topic:Cannot build the HelloWorld plugin
Next Topic:[PDE] What do "hollow J" icons mean?
Current Time: Thu Nov 06 08:08:25 EST 2025
Powered by FUDForum. Page generated in 0.05133 seconds
