Home » Eclipse Projects » DSDP - Target Management » PHP Project Outline is not working with remote project
PHP Project Outline is not working with remote project [message #17585] Sat, 29 December 2007 04:52 Go to next message
Originally posted by: muzehyun.gmail.com
windows XP
eclipse 3.3.1.1
java PDT target management
'Create Remote Project' from remote system view (some folder over sftp
connection)
And folder is created in PHP Explorer view
However when I edit php file, nothing is changed in PHP Project Outline view
And it is normally working with local files
Is there any way to solve this problem?
Thank you
Sean
Re: PHP Project Outline is not working with remote project [message #17598 is a reply to message #17585] Sun, 30 December 2007 22:49 Go to previous message
Hi Sean,
The Outline view doesn't show anything because PHP files in a general
project don't show an outline view. The Create Remote Project action
will create a general project not a PHP project. To get this to work
you need to create the remote project differently.
You need to create a local PHP project and link folders. To link
folders right click on the project and select New -> Folder. Click on
Advanced. Select "Link to file in the file system". Change the file
system to RSE. Click Browse and find the folder you would like to link.
Bug #213621 ( https://bugs.eclipse.org/bugs/show_bug.cgi?id=213621 ) is
open for linking files.
Also some discussion about improving the Create Remote Project action
can be found on Bug #201438 (
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201438 ).
Kevin Doyle
Sean Kim wrote:
> windows XP
> eclipse 3.3.1.1
> connection)
> Thank you
> Sean
Re: PHP Project Outline is not working with remote project [message #571638 is a reply to message #17585] Sun, 30 December 2007 22:49 Go to previous message
Hi Sean,
Kevin Doyle
Sean Kim wrote:
> windows XP
> eclipse 3.3.1.1
> connection)
> Thank you
> Sean
Previous Topic:PHP Project Outline is not working with remote project
Next Topic:Remote Workspace
Current Time: Fri Nov 07 02:10:21 EST 2025
Powered by FUDForum. Page generated in 0.03967 seconds
