Unable to view JDK source referenced in stack traces [message #185993] |
Fri, 29 December 2006 01:02 |
Originally posted by: qu0llSixFour.gmail.com
Whenever my application throws an exception that occurs inside the JDK
source code, the source is not available (it says "Unknown Source") so I am
unable to determine the line number or browse the source. Why is this and
how do I fix it? If I go into Preferences JRE_SRC is pointing to the
src.zip in the correct location. I am using Eclipse 3.3M1 and Java 6.0
FCS. What else should I be looking at? Exceptions thrown from my own
source are not affected by this problem.
And loving it,
qu0ll
______________________________________________
qu0llSixFour@gmail.com
(Replace the "SixFour" with numbers to email)
FUDForum. Page generated in 0.08091 seconds
