a way to restrict the size of Labels? [message #185988] |
Thu, 30 June 2005 19:26  |
Hi there,
I have a Label figure which I would like to impose a minimum size and
maximum size upon.
For example, I want the figure to be between 50 and 200 pixels wide. If the
label text is too long to fix within 200 pixels, then I want it to display
the "..." ellipses to indicate the truncation.
The label is being used within a Figure which has a horizontal flow layout.
It seems that in a flow layout, the size of the label is totally determined
by the result of getPreferredSize (please correct me if I'm mistaken; I
tried "setMinimumSize" and "setMaximumSize" to no avail).
The problem is that I can't seem to get both behaviours -- a maximum size
limit and the ellipses to show truncation -- mainly because the GEF
algorithm to determine whether to show "..." depends on getPreferredSize.
Is there a *nice* way to solve this issue?
Below is the code that I implemented on the label to get it to appear within
my size constraints.
Thanks.
Label label = new Label ()
public Dimension getPreferredSize (int wHint, int hHint)
// Force this label to be bigger than the default min size
and smaller than the max
Dimension size = new Dimension (super.getPreferredSize
(wHint, hHint));
size.width = Math.max (size.width, minLabelWidth);
size.width = Math.min (size.width, maxLabelWidth);
return size;
Re: a way to restrict the size of Labels? [message #186952 is a reply to message #185988] |
Thu, 07 July 2005 15:22  |
Originally posted by: none.unknown.com
Subclass FlowLayout and enforce the size restrictions there.
"Damian" <damian_biollo@hotmail.com> wrote in message
news:da1v2b$oe2$1@main1.eclipse.org...
> Hi there,
> maximum size upon.
the
layout.
determined
within
> Thanks.
> (wHint, hHint));
> return size;
FUDForum. Page generated in 0.15514 seconds
