Home » Archived » M2M (model-to-model transformation) » [Announce] A Proposal and Prototype for an Eclipse Model Registry
[Announce] A Proposal and Prototype for an Eclipse Model Registry [message #17559] |
Mon, 19 February 2007 16:32  |
[Apologies for multiple postings. Please reply to the GMT newsgroup posting.]
Context
A model transformation is declared:
e.g. in QVTrelation
transformation SeqToStm(seqDgm: SeqMM; stm: StmcMM)
the seqDgm model complying with the SeqMM meta-model is transformed to/from the stm model complying with the STmcMM meta-model.
Problem
How are the (models and) meta-models located?
e.g. where is the definition that
SeqMM ==> platform:/resource/QvtrTestFiles/ModelMorfExamples/SeqToStm/ SeqMM.xml
[assuming that there is no entry in the EMF package registry, since SeqMM.xml is a user artefact for which no plugin has been built
and installed as an Ecore model.]
Analysis
The above example happens to be a line from a QVTrelation example from ModelMorf.
I have seen the same problem with ATL, MOFscript and Tefkat, and presume that it exists for all tools that exploit meta-models.
I have seen some rather poor solutions to this problem that are barely adequate for application of transformations and difficult to
generalise across tools.
I am writing a QVTrelation context sensitive editor, and so the editor needs to resolve the meta-models in order to perform
meta-model compliance validation. Use of solutions specific to application of transformations will not suffice. It must be possible
to double click the QVTrelation source to open the editor, and it is not acceptable to modify the source file in order to include
the platform-specific meta-model bindings.
Solution
A user configurable registry of 'model accessor' to 'platform resource' is required, where 'model accessor' can be an informal model
name, such as 'SeqMM' or a URI such as 'http:/my/seq/mm', and platform resource is a simple URI such as
'file:/C:/My/seq/metamodel.xml' or an installed Eclipse resource such as 'platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore'
The Proposed Eclipse Model Registry (currently available as a prototype from the GMT UMLX Update site
http://download.eclipse.org/technology/gmt/umlx/updates
or CVS at org.eclipse.gmt/umlx/plugins/org.eclipse.gmt.umlx.registry on /cvsroot/technology)
maintains a ModelRegistry model in 'project'/.settings/org.eclipse.gmt.umlx.registry.modelregis try
with per-resource bindings of model accessor to platform resource. Resolution of these bindings is hierarchical, so a binding for a
file, applies only to a file, whereas a binding to a folder applies to all files within the folder and sub-folder, and a binding to
a project applies throughout the project.
Once the Model Registry Nature is added to a project (via the right button menu on a project), resources within the project acquire
Model Registry Property Page (via the Properties selection on the right button menu on the resource). The Model Registry Property
Page provides a GUI for defining the 'model accessor' to 'platform resource' bindings.
The binding also includes a serialisation type, which may be defined to something other than XML to allow non-XML models (e.g. KM3)
to be bound.
Tool support
In order to exploit this registry tools should construct a ModelResourceResolver for the IResource (file) for which resources are to
be resolved, optionally specifying a ResourceSet to be used during resolution.
String metaId = ...; // model for resolution
IResource file = ...; // context for resolution
ResourceSet resourceSet = new ResourceSetImpl(); // or EcoreFamilyResourceSetImpl()
ModelResourceResolver resolver = new ModelResourceResolver(file, resourceSet);
URI uri = resolver.getURI(modelId); // Get platform resource URI or null
Resource resource = resolver.getResource(uri, true); // Same API as ResourceSet.getResource()
EMOF Support
EMF currently allows EMOF models to be used in place of Ecore models, provided the file extension of the EMOF models is distinct and
provided that the EMOFResourceFactoryImpl has been registered for those extensions with the extension to factory map
(resourceSet.getResourceFactoryRegistry().getExtensionToFact oryMap()).
If EcoreFamilyResourceSetImpl is used in place of ResourceSetImpl, the URI of the namespace of the root XML element is examined and
an appropriate content dependent ResourceFactory is used to load the XML file. EMOF and Ecore models can then be used
interchangeably regardless of file extension.
Extension point hooks
The model_accessor extension point defines, the kinds of keys for accessing the model registry. By default ModelName and URI keys
are provided. Additional keys may be defined.
The model_content extension point defines the mapping from the URI of the namespace of an XML element to the Resource.Factory that
supports that XML model format. By default Ecore and EMOF are supported. Other XML formats may be defined.
The model_serialisation extension point defines the mapping from non-XML serialisations of a model and the Resource.Factory that
converts that serialisation to/from Ecore. Only the default XML serialisation is supported by default.
Summary
This proposal and prototype is intended to be entirely generic; it has no UMLX-specific functionality.
It is hoped that tools will experiment with it, so that the API can be validated and in due course the prototype migrate to become
part of EMF.
The code was developed using JDK 1.6.0 and Eclipse 3.3M4. It requires at least J2SE1.5, and appears to work on Eclipse 3.2.1. The
Model Registry pages appear to work only for folders and files on Eclipse 3.2.
Comments and Feedback very welcome.
Ed Willink
Re: [Announce] A Proposal and Prototype for an Eclipse Model Registry [message #486934 is a reply to message #17559] |
Mon, 21 September 2009 04:43   |
I have seen the proposal for this component at
http://www.eclipse.org/proposals/emf-registry/
how do I add myself as an interested party?
Javi
> posting.]
> Context
> e.g. in QVTrelation
> Problem
> SeqMM ==>
> SeqMM.xml is a user artefact for which no plugin has been built and
> Analysis
> ModelMorf.
> adequate for application of transformations and difficult to generalise
> across tools.
> needs to resolve the meta-models in order to perform meta-model
> transformations will not suffice. It must be possible to double click
> modify the source file in order to include the platform-specific
> Solution
> is required, where 'model accessor' can be an informal model name, such
> a simple URI such as 'file:/C:/My/seq/metamodel.xml' or an installed
> Resolution of these bindings is hierarchical, so a binding for a file,
> files within the folder and sub-folder, and a binding to a project
> button menu on a project), resources within the project acquire Model
> menu on the resource). The Model Registry Property Page provides a GUI
> something other than XML to allow non-XML models (e.g. KM3) to be bound.
> Tool support
> to be resolved, optionally specifying a ResourceSet to be used during
> resolution.
> resourceSet);
> EMOF Support
> provided the file extension of the EMOF models is distinct and provided
> URI of the namespace of the root XML element is examined and an
> file. EMOF and Ecore models can then be used interchangeably regardless
> of file extension.
> accessing the model registry. By default ModelName and URI keys are
> the namespace of an XML element to the Resource.Factory that supports
> serialisations of a model and the Resource.Factory that converts that
> Summary
> validated and in due course the prototype migrate to become part of EMF.
> least J2SE1.5, and appears to work on Eclipse 3.2.1. The Model Registry
> Regards
> Ed Willink
Re: [Announce] A Proposal and Prototype for an Eclipse Model Registry [message #487396 is a reply to message #486934] |
Wed, 23 September 2009 01:51  |
Hi Francisco
The proposal is not supposed to be visible or linked to.
The proposal has been withdrawn because creation of an Incubation
project used by a mature project such as MDT/OCL would be anomalous.
The model registry will therefore be provided as part of MDT/OCL for the
Helios release.
Please use the MDT/OCL newsgroup to express your interest. (Thank you
in advance.)
A prototype is available (most conveniently from CVS) as part of the
M2M/QVT Declarative project. The OCL migration will involve a number
of package and path name changes.
Ed Willink
Francisco Javier Cano wrote:
> Hello,
> Javi
>> posting.]
>> Context
>> e.g. in QVTrelation
>> Problem
>> SeqMM ==>
>> Analysis
>> ModelMorf.
>> Solution
>> resource is a simple URI such as 'file:/C:/My/seq/metamodel.xml' or an
>> button menu on the resource). The Model Registry Property Page
>> resource' bindings.
>> to something other than XML to allow non-XML models (e.g. KM3) to be
>> bound.
>> Tool support
>> resolution.
>> resolution
>> resourceSet);
>> EMOF Support
>> Summary
>> at least J2SE1.5, and appears to work on Eclipse 3.2.1. The Model
>> Regards
>> Ed Willink
Current Time: Sat Jul 26 09:19:32 EDT 2025
Powered by FUDForum. Page generated in 0.25577 seconds
