Home » Archived » BIRT » 3.1 support
3.1 support [message #17530] Thu, 10 March 2005 13:32 Go to next message
When will BIRT support Eclipse 3.1? Running the first preview build, there
are a few errors.
-Chris
Re: 3.1 support [message #17575 is a reply to message #17530] Thu, 10 March 2005 21:15 Go to previous messageGo to next message
Which version of 3.1 are you running?
I have been working with 3.1.0 Build id: 200408122000 and have not had any
significant problems.
Scott Rosenbaum
BIRT PMC
"Chris" <schtoo@schtoo.com> wrote in message
news:d0q3th$t84$1@www.eclipse.org...
there
> are a few errors.
> -Chris
Re: 3.1 support [message #17707 is a reply to message #17575] Fri, 11 March 2005 15:30 Go to previous messageGo to next message
I had some trouble running the tutorial under 3.1M5a due to problems in the
data explorer view. Filed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=87803 .
Ed Burnette
www.eclipsepowered.org
"Scott Rosenbaum" <scottr@innoventsolutions.com> wrote in message
news:d0qv17$ptt$1@www.eclipse.org...
Scott Rosenbaum
BIRT PMC
Re: 3.1 support [message #17720 is a reply to message #17707] Fri, 11 March 2005 16:22 Go to previous messageGo to next message
Wouldn't you know it. Now that I try to go back and reproduce the errors I
can't. I know I wasn't imagining things. I was getting the same error all
over. I now can't find how I caused it (though once I found it, it started
showing up everywhere), but I do have a copy of the stack trace from the
log:
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.ClassCastException:
org.apache.xerces.jaxp.DocumentBuilderFactoryImpl
at javax.xml.parsers.DocumentBuilderFactory.newInstance(Unknown Source)
at org.eclipse.ui.XMLMemento.createWriteRoot(XMLMemento.java:13 9)
org.eclipse.ui.internal.Workbench.recordWorkbenchState(Workb ench.java:1386)
at org.eclipse.ui.internal.Workbench.access$3(Workbench.java:13 84)
....etcc....
The root cause is nothing BIRT related, but I've never seen this error until
I installed BIRT and even then only after messing around with a report
template.
-Chris
"Ed Burnette" <ed.burnette@sas.com> wrote in message
news:d0sv58$fn1$1@www.eclipse.org...
> Ed Burnette
> Scott Rosenbaum
> BIRT PMC
Re: 3.1 support [message #19922 is a reply to message #17575] Thu, 17 March 2005 05:12 Go to previous messageGo to next message
Originally posted by: ekkehardREMOVE_NO_SPAM.gentz-software.de
hi scott,
good to hear that birt runs with 3.1M5a.
I'll start heavy testing BIRT in 2-3 weeks,
then you'll hear more from me and the proposed scenarios ;-)
(I don't forgot out talk at eclipseCon)
regards
ekkehard
erpOS ERP Open Source Software
> Scott Rosenbaum
> BIRT PMC
> there
>>are a few errors.
>>-Chris
Re: 3.1 support [message #20035 is a reply to message #19922] Thu, 17 March 2005 09:57 Go to previous messageGo to next message
Ekkehard,
Good to hear from you. Hope the project is going well. I should have
been a little more precise in my description of BIRT and 3.1.
I was using 3.1.0 M1. While at the conference, I witnessed someone
working with 3.1 M5a and saw that they were having some fairly
significant issues with the rendering in some of the dialogs. I am in
the process of setting up an additional system that I will use to run
3.1 M5++ but I don't think that BIRT is quite ready to run there.
As far as I know, the BIRT developers primary goal is to have a stable
release for 3.0.1 available by May 1. I don't think there will be any
work on compatibility with 3.1 until Release 1 is complete.
Scott Rosenbaum
BIRT PMC
ekkehard wrote:
> hi scott,
> regards
> ekkehard
>> had any
>> Scott Rosenbaum
>> BIRT PMC
>> there
>>> are a few errors.
>>> -Chris
Re: 3.1 support [message #20074 is a reply to message #20035] Thu, 17 March 2005 11:30 Go to previous messageGo to next message
hi scott,
because we're building a RCP we really need the things from 3.1M5a+
so we have decided to make all our development using 3.1 milestones.
if BIRT doesn't run under actual Milestones then we cannot make tests :-(
regards
ekkehard
> Ekkehard,
> Scott Rosenbaum
> BIRT PMC
> ekkehard wrote:
>> hi scott,
>> regards
>> ekkehard
>>> had any
>>> Scott Rosenbaum
>>> BIRT PMC
>>> there
>>>> are a few errors.
>>>> -Chris
Re: 3.1 support [message #20463 is a reply to message #20074] Thu, 17 March 2005 14:34 Go to previous messageGo to next message
We're in the exact same situation. We're developing an RCP app on 3.1.
BIRT only supporting 3.0 (even to start) doesn't bode well :(
-Chris
"ekkehard" <ekkehardREMOVE_NO_SPAM@gentz-software.de> wrote in message
news:d1cbbd$dva$1@www.eclipse.org...
> hi scott,
> regards
> ekkehard
>> Ekkehard,
>> the process of setting up an additional system that I will use to run 3.1
>> Scott Rosenbaum
>> BIRT PMC
>> ekkehard wrote:
>>> hi scott,
>>> regards
>>> ekkehard
>>>> any
>>>> Scott Rosenbaum
>>>> BIRT PMC
>>>> there
>>>>> are a few errors.
>>>>> -Chris
Re: 3.1 support [message #20628 is a reply to message #20463] Sat, 19 March 2005 00:35 Go to previous message
The development team plans to support Eclipse 3.1 within 30 days after the
final 3.1 release. However, if the community can identify specific problems
before then, the development team will try to fix them as part of the BIRT
release 1.0 work. Please file any problems you find in Bugzilla.
- Paul
Paul Rogers
BIRT PMC
news:d1cm5j$cqq$1@www.eclipse.org...
> -Chris
>> hi scott,
>> regards
>> ekkehard
>>> Ekkehard,
>>> Scott Rosenbaum
>>> BIRT PMC
>>> ekkehard wrote:
>>>> hi scott,
>>>> regards
>>>> ekkehard
>>>>> any
>>>>> Scott Rosenbaum
>>>>> BIRT PMC
>>>>> there
>>>>>> are a few errors.
>>>>>> -Chris
Previous Topic:Report Designer Option
Next Topic:Tutorial - need help please.
Current Time: Wed Nov 12 09:05:53 EST 2025
Powered by FUDForum. Page generated in 0.05169 seconds
