Home » Eclipse Projects » DSDP - Target Management » Easy Install Question
Easy Install Question [message #17523] Wed, 12 December 2007 15:51 Go to next message
Originally posted by: brettieee.yahoo.com
Hi Everyone
I am trying to install the RSE on eclipse with the update manager. When I
go to find new things to install and select the Target Management Site, it
says
Target Management Service Discovery (2.0.0.v20070611-7J--E8McIJNJCPr)
requires plug-in "org.eclipse.emf.ecore (2.2.0)", or compatible.
Where can I find that plugin. Is there a remote site I can point to to
automatically get it and install it? I have been looking forever. I
would appreciate any help that anyone could offer.
THanks Alot
Re: Easy Install Question [message #17534 is a reply to message #17523] Thu, 13 December 2007 13:49 Go to previous messageGo to next message
Hi Brett,
You can use the Europa update site to find EMF or you can use this
update site: http://download.eclipse.org/modeling/emf/updates/site.xml
If you are installing all of Target Management you will also need to
install CDT for the Remote C/C++ Debug Launcher. Which can also be
found on the Europa update site or
http://download.eclipse.org/tools/cdt/releases/europa
If you do not need the Service Discovery or the Remote C/C++ Debug
Launcher you can click on the + beside Target Management in the update
manager to expand it and select only the options you want to install.
Kevin Doyle
Brett Kaufman wrote:
> Hi Everyone
> I go to find new things to install and select the Target Management
> Site, it says
> THanks Alot
Re: Easy Install Question [message #17547 is a reply to message #17534] Tue, 18 December 2007 03:55 Go to previous message
Needless to say, the Europa Discovery site comes preconfigured
with your Eclipse Platform installation. Just
Help > Software Updates > Find and Install >
Search for New Features > Europa Discovery Site
You'll find TM and RSE under the Remote Access and Device Development
category. Select what you want, the press the "Select Required" button.
Martin
Kevin Doyle schrieb:
> Hi Brett,
Martin Oberhuber
Wind River Systems, Inc.
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Re: Easy Install Question [message #571479 is a reply to message #17523] Thu, 13 December 2007 13:49 Go to previous message
Hi Brett,
Kevin Doyle
> Hi Everyone
> Site, it says
> THanks Alot
Re: Easy Install Question [message #571509 is a reply to message #17534] Tue, 18 December 2007 03:55 Go to previous message
Martin
> Hi Brett,
Martin Oberhuber
Previous Topic:Easy Install Question
Next Topic:Many Save Conflicts
Current Time: Tue Nov 18 17:37:58 EST 2025
Powered by FUDForum. Page generated in 0.05144 seconds
