Home » Archived » M2M (model-to-model transformation) » [ATL] programatically launch already loaded model
| [ATL] programatically launch already loaded model [message #17519] |
Fri, 16 February 2007 20:28  |
Originally posted by: irbull.cs.uvic.ca
Is there a way to call a transform (programatically) on an already
loaded EMF model?
I have an EMF model that is already loaded and I would like to run a
transform on it. I don't want to reload it because it is rather large?
That is I don't want to:
ASMModel model = amh.loadModel(file.getName(), amh.getMof(), in);
thoughts,
cheers,
ian
| Re: [ATL] programatically launch already loaded model [message #17535 is a reply to message #17519] |
Sat, 17 February 2007 13:19   |
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Ian,
I think you should take a look to the method loadASMEMFModel(String
name, ASMEMFModel metamodel, Resource extent, ModelLoader ml) available
if you directly use the class ASMEMFModel (you can use "null" for the ml
parameter).
I hope this help you to handle your large model (maybe NHL data ;-))
Freddy
> loaded EMF model?
> thoughts,
> cheers,
> ian
| Re: [ATL] programatically launch already loaded model [message #17546 is a reply to message #17535] |
Sat, 17 February 2007 21:40   |
Cool, Thanks Freddy, I will take a look at this...
and yep, my NHL Data... The things I can play with as a student :)
- ian
Freddy Allilaire wrote:
> Hi Ian,
> parameter).
> Freddy
>> loaded EMF model?
>> thoughts,
>> cheers,
>> ian
| Re: [ATL] programatically launch already loaded model [message #17573 is a reply to message #17546] |
Mon, 19 February 2007 22:57   |
Cool, this works!
However, my resource is loaded from Static EMF (not dynamic emf). Is
there a way to specify a metamodel from its EPackage?
cheers,
ian
> - ian
>> Hi Ian,
>> available if you directly use the class ASMEMFModel (you can use
>> "null" for the ml parameter).
>> Regards,
>> Freddy
>>> loaded EMF model?
>>> large? That is I don't want to:
>>> thoughts,
>>> cheers,
>>> ian
| Re: [ATL] programatically launch already loaded model [message #17586 is a reply to message #17573] |
Tue, 20 February 2007 01:09   |
I assume this is the problem, maybe not?
Basically it doesn't seem like my rules are matching any elements.
When I finish the transform and say:
outputModel.getExtent().getContents()
I get 0 elements.
The transformation is very simple:
module ExampleTransformation; -- Module Template
create OUT : BARCHART from IN : VIEWSHAPER;
rule Example {
from s : VIEWSHAPER!Node
to t : BARCHART!Item (
label <- s.toString()
and my model is nothing but VIEWSHAPER!Node, (there are lots of them :)
Actually, it doesn't matter what I put after BARCHAR!blah. It seems
like this never matches.
Is there a good way to debug this when called programmatically?
cheers,
ian
Ian Bull wrote:
> Cool, this works!
> cheers,
> ian
>> - ian
>>> Hi Ian,
>>> Regards,
>>> Freddy
>>>> loaded EMF model?
>>>> thoughts,
>>>> cheers,
>>>> ian
| Re: [ATL] programatically launch already loaded model [message #17600 is a reply to message #17586] |
Tue, 20 February 2007 02:59  |
No worries... I think I have it!
I used the same thing for my metamodels:
ASMEMFModel.loadASMEMFModel("VIEWSHAPER", (ASMEMFModel)amh.getMof(),
ViewshaperPackage.eINSTANCE.eResource(), null);
and said ViewshaperPackage.eINSTANCE.eResource for my metamodel.
cheers,
ian
> I get 0 elements.
> rule Example {
> cheers,
> ian
> Ian Bull wrote:
>> Cool, this works!
>> cheers,
>> ian
>>> - ian
>>>> Hi Ian,
>>>> Regards,
>>>> Freddy
>>>>> loaded EMF model?
>>>>> a transform on it. I don't want to reload it because it is rather
>>>>> thoughts,
>>>>> cheers,
>>>>> ian
Current Time: Fri Nov 07 09:38:50 EST 2025
Powered by FUDForum. Page generated in 0.04596 seconds
