Home » Language IDEs » Java Development Tools (JDT) » Getting the IClassFile of ICompilationUnit
Getting the IClassFile of ICompilationUnit [message #185421] Fri, 12 November 2004 10:19 Go to next message
Originally posted by: newaym.hotmail.com
hi,
i'm looking for a specific IClassFile, which is inside a selected IProject.
Finding the ICompilationUnit using the SearchEngin or iterating through
IPackageFragments seems to easy.
but how do you get the IClassFile?
many thanks in advance.
tanaysy
Re: Getting the IClassFile of ICompilationUnit [message #185445 is a reply to message #185421] Fri, 12 November 2004 12:36 Go to previous messageGo to next message
use IPackageFragment.getClassFile
/adam
Re: Getting the IClassFile of ICompilationUnit [message #217230 is a reply to message #185421] Tue, 18 October 2005 12:41 Go to previous message
Originally posted by: rotsch_mulla.yahoo.de
Hi!
IProject.
I have a follow-up question to this older thread.
What I want to do is to get the absolute path to a class file. However I
only have an IMethod retrieved from an ISelection. From what I
understand from several other posts and the Javadoc API I could now
* get the ICompilationUnit from the IMethod and retrieve the
IPackageFragment and the IJavaProject from it and then
* use the IPackageFragment.getClassFile method with the class name I get
from the ICompilationUnit (minus .java plus .class) to get the
IClassFile, which I can use in turn to get the relative path and then
* use the IJavaProject.geOutputLocation to get the output path and then
* combine both informations for a still relative link to the sought
class file.
I'm just wondering if that really is the easiest way to find the class
file corresponding to a source file, the solution I outlined seems to be
too complicated for such an everyday task ...
Any hints are appreciated!
-Rotsch
Previous Topic:APT for 3.1.1
Next Topic:IType and generics (determining the content of List<MyClass> given the IType)
Current Time: Sun Jun 22 13:41:52 EDT 2025
Powered by FUDForum. Page generated in 0.03155 seconds
