metrics mixup [message #185409] |
Tue, 27 January 2004 09:11  |
Originally posted by: leila.hagen.state.mn.us
I am running eclipse 2.1.2 and have installed both the metrics 1.3.4 from
sourceforge and TeamInABox eclipse metrics plugin 2.3.0. Neither one works,
even though both the "Enable Metrics" and "Enable Metrics Gathering"
properties are checked on both Metrics project properties.
In the 1.3.4 metrics view, the window stays gray and says "No metrics
available for selection," even after a full recompile in the java
perspective. If I try to use the ant build task, a dos window pops up that
appears to be waiting for some kind of input but never actually does
anything.
TeamInABox sort of works, but only using the "Export Metrics" option.
How can I resolve either problem? Any clues would be greatly appreciated.
Thanks in advance,
Leila
Re: metrics mixup [message #185482 is a reply to message #185409] |
Tue, 27 January 2004 10:35   |
Originally posted by: hcs33.egon.gyaloglo.hu
Have you seen "Measuring..." text in the dialog after enabling TeamInABox
plugin? If yes but there are no items in the Tasks view then the problem is
with task filtering. Make sure that you enabled the Problem type "Metrics
Marker" in the Task Filters dialog (can select from the view's title bar).
HTH,
Csaba
"Leila" <leila.hagen@state.mn.us> wrote in message
news:bv5rbm$69j$1@eclipse.org...
> Hello,
works,
> anything.
> Thanks in advance,
> Leila
Re: metrics mixup [message #185633 is a reply to message #185608] |
Tue, 27 January 2004 14:15  |
Originally posted by: eclipse-user.jibeinc.com
Leila wrote:
> Thanks! Now the TeamInABox metrics are working. The SourceForge Metrics
> 1.3.4 still does not. Maybe I'll try installing that separately to see if it
> will work then.
Have you tried looking through or posting to the Metrics plugin forum at
SourceForge (http://sourceforge.net/forum/?group_id=70202)? Or email the
author - he's a nice guy and likely can answer your problem directly.
HTH,
Eric
> "Horváth, Csaba" <hcs33@egon.gyaloglo.hu> wrote in message
> news:bv60cd$dht$1@eclipse.org...
>>Hi,
> is
>>HTH,
>>Regards,
>>Csaba
>>>Hello,
> from
>>works,
> that
>>>anything.
> appreciated.
>>>Thanks in advance,
>>>Leila
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
FUDForum. Page generated in 0.04141 seconds
