| Re: Release candidate 0.9.0 at Q4E [message #18681 is a reply to message #18658] |
Wed, 29 April 2009 13:20   |
Hello Marek,
Thanks for your report... see below for some comments.
Marek Romanowski wrote:
> 3. After a few out of memory errors something strange occured:
> - I could open file (.java for example)
> - I could edit it (adding some text)
> - I couldn't(!) save it, because save operation was blocked until some
> other operation finish.
> In Progres view I saw only sleeping "Synchronizing task list" and my save
> operation. Restarts (some with -clean option) did not help - situation was
> the same. I had do uninstall IAM and that helped.
> Sorry for lack of details, I don't know how to give you more description.
> If you have some questions, possible solution or could describe where to
> find any logs from IAM work i would try to reproduce situation and post
> results.
IAM writes to the eclipse log, so that's the first place where you could
look for possible errors.
If you are able to test again, please:
- open the Events view, so you can see any messages by maven. Remember to
change the filter to "debug" level so you can see all output
- I have to verify this, but it is possible that the first maven run
after importing a project is locking the project and not showing on the
progress view. With 50+ projects, it might take some time for maven to
run, specially in online mode (the default).
Regaring the out of memory exceptions, maybe you could workaround them by
importing progects in smaller groups?
Abel Muiño
| Re: Release candidate 0.9.0 at Q4E [message #18790 is a reply to message #18770] |
Tue, 05 May 2009 16:25  |
> Is it possible that this version of IAM changes pom.xml files by sorting
> elements (to standard maven way) and removing namespace declarations from
> <project> element? I'm not sure is it a problem with IAM, but from short
> time my pom's are modified in this manner without prompt.
I have never seen this, but it is possible that things like that could
happen if you use any of the actions which modify the pom programatically
(adding/removing dependencies and many controls in the visual pom editor
can alter collections of pom elements).
If you are not using another tool to edit your pom, then it probably is
IAM (although I doubt it is specific to this new version).
It would be most useful if you could find a test case of this behaviour!
Thanks!
Abel Muiño
| Re: Release candidate 0.9.0 at Q4E [message #568753 is a reply to message #17493] |
Tue, 28 April 2009 21:01  |
A new build has been published with a fix (when reopening a project,
other projects' classpath might not be updated) and the ability to
detect dependencies in the workspace when using version ranges.
On 4/20/09 11:51 AM, Carlos Sanchez wrote:
> I have prepared a release candidate of 0.9.0 at the old Q4E site (due to
> the IP process we can't release at Eclipse yet)
> Instructions to update from Q4E are at
> http://code.google.com/p/q4e/wiki/UpgradingToEclipseIAM
> Please test and provide feedback.
> Thanks
| Re: Release candidate 0.9.0 at Q4E [message #568772 is a reply to message #18637] |
Wed, 29 April 2009 09:28  |
I've installed q4e 0.9.0 at April 28 (before your update) and have some
comments:
1. Adding maven nature works a lot faster. I have >100 projects under
eclipse&maven and with previous version "updating classpath" worked so
slow, I couldn't take it as a development environment.
2. Unfortunatelly eclipse run out of memory while adding ~50 projects. I
have -Xmx1g arg in my eclipse.ini, so i don't think it's too small. I was
planning to dump memory and analyze it, but 3. happened.
I was thinking that some information could be written in plugin
configuration. Then after restart, because of this info, some process
started but did not report to Progress View. I'm not able to describe
situation more accuratelly.
results.
Cheers!
Marek.
| Re: Release candidate 0.9.0 at Q4E [message #568786 is a reply to message #18658] |
Hello Marek,
> results.
Abel Muiño
| Re: Release candidate 0.9.0 at Q4E [message #568809 is a reply to message #18681] |
Wed, 29 April 2009 15:17  |
I've dumped JVM memory on OutOfMemoryError and started to analyze it with
Eclipse Memory Analyzer. I think there is some problem with MavenLog
class. One of instances points to a String 275MB big... Connections go
like this:
MavenEventStore -> CircularFifoBuffer -> Object -> MavenLog ->
String -> char[137022158]
So it looks like MavenEventStore stores logs in CircularFifoBuffer. CFB
has got array of logs (array size: 10000). Array holds reference to a
MavenLog which references enormous String (137022158 characters). This
String starts with: " (f) classpathElements = [" - after this goes
classpath elements from my project; two first chars are whitespaces.
I think this take place only while plugin enables maven dependency
management. Maybe when I'm enabling it for 50+ projects at one operation,
this log is concatenated between all of them?
I hope this will help you,
Marek.
| Re: Release candidate 0.9.0 at Q4E [message #568826 is a reply to message #18702] |
Wed, 29 April 2009 16:24  |
Unless there is a bug (which, by the size of the string, is quite
possible), each MavenLog is an object representing a log message from
maven (along with other formatting information).
It looks like maven is generating this gigantic string for your build.
Could you try one more thing?
Run a command line build with debug output enabled and look for the
string in the output:
mvn -X process-test-resources > build.log
This will not be 100% accurate (since IAM uses a non-released version of
maven) but with some luck it might help us to determine if maven is
creating this string or is something in IAM.
> like this:
> Marek.
| Re: Release candidate 0.9.0 at Q4E [message #568854 is a reply to message #18725] |
Thu, 30 April 2009 07:28  |
I'm using Maven 2.1.0 and for all projects I've enabled with IAM build.log
is 1407565 bytes big.
More huge log details: there is 1701146 classpath elements in it, but only
326 unique. Log severity is debug. As you said it could be problem with
specific version of maven used in IAM. Is it possible to change it to
default maven distribution installed on system?
| Re: Release candidate 0.9.0 at Q4E [message #568886 is a reply to message #18637] |
Tue, 05 May 2009 15:24  |
| Re: Release candidate 0.9.0 at Q4E [message #568916 is a reply to message #18770] |
Thanks!
Abel Muiño
FUDForum. Page generated in 0.05979 seconds
