Home » Eclipse Projects » GEF » GEFrc3,eclipse RC3:draw2d can not get the correct result?
GEFrc3,eclipse RC3:draw2d can not get the correct result? [message #185139] Wed, 22 June 2005 22:17 Go to next message
Simple code copied from the draw2d sample:
import org.eclipse.swt.widgets.Shell;
import org.eclipse.draw2d.*;
import org.eclipse.swt.SWT;
import org.eclipse.draw2d.geometry.*;
public class Test1 {
public static void main(String args[]){
Shell shell = new Shell();
shell.open();
shell.setText("Draw2d");
LightweightSystem lws = new LightweightSystem(shell);
lws.getRootFigure().setBackgroundColor(ColorConstants.white) ;
IFigure panel = new Panel();
panel.setLayoutManager(new FlowLayout());
lws.setContents(panel);
Clickable button = new Button("Click me");
Clickable checkbox = new CheckBox("Check box");
Shape ellipse = new Ellipse();
ellipse.setBackgroundColor(ColorConstants.darkBlue);
ellipse.setOpaque(true);
Shape rectangle = new RectangleFigure();
rectangle.setBackgroundColor(ColorConstants.lightBlue);
rectangle.setOpaque(true);
panel.add(button);
panel.add(checkbox);
panel.add(ellipse);
panel.add(rectangle);
Display display = Display.getDefault();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ())
display.sleep ();
I can't see the ellipse and rectangle?
Re: GEFrc3,eclipse RC3:draw2d can not get the correct result? [message #185166 is a reply to message #185139] Thu, 23 June 2005 05:45 Go to previous messageGo to next message
Do you not have to setSize() first?
e.g
ellipse.setSize(15,15);
rectangle.setSize(15,15);
Re: GEFrc3,eclipse RC3:draw2d can not get the correct result? [message #185321 is a reply to message #185166] Fri, 24 June 2005 04:33 Go to previous messageGo to next message
Thank you!
but that code can run under previous version, that is funny! It must be
something changed in the newer version!
"Asim Ullah" <asimullah@hotmail.com>
??????:201ea58c67ad4f103212752129d8c61f$1@www.eclipse.org...
> e.g
Re: GEFrc3,eclipse RC3:draw2d can not get the correct result? [message #185431 is a reply to message #185321] Sat, 25 June 2005 00:19 Go to previous message
Yes, Figures now have a size of 0,0. This is an optimization which reduces
the amount of painting when editing a diagram.
"kavinwang" <kavin.fy.wang@gmail.com> wrote in message
news:d9ggh7$pn9$1@news.eclipse.org...
> Thank you!
>> e.g
Previous Topic:Why is UndoablePropertySheetEntry final?
Next Topic:Saving as an XML document
Current Time: Thu Nov 06 18:28:04 EST 2025
Powered by FUDForum. Page generated in 0.03426 seconds
