| focus on active task button is missing in Package Explorer [message #17474] |
Sat, 21 July 2007 07:47  |
After I installed Eclipse 3.3 final (Europa) and Mylyn 2.0 (final) and strange situation occurred. In Package Explorer view the active task button is missing. I also have the same Eclipse and Mylyn versions installed on my working computer and there is not such problem at all. I've tried to solve the problem but without success.
It's a incorrect settings problem, a installation problem, a plugins conflict problem or is simply a bug. Please let me know because mylyn is the most useful plugin for me. And the new Xplanner connector extends its power.
Thanks a lot, jtonic.
P.S. Uninstall the mylyn, remove the .mylyn folder and reinstall it didn't solve the problem.
| Re: focus on active task button is missing in Package Explorer [message #19844 is a reply to message #18927] |
Thu, 26 July 2007 17:34  |
I've tried what you advise me to do but without success. I will fill a
bug. It's pretty strange that the "focus on active task" button is visible
in other views but not in Package Explorer one. Error Log view doesn't
contains nothing about Mylyn (in fact error log contains only few messages
with "OK" severity - Could not install bundle...)).
Thanks a lot for your advices
On Wed, 25 Jul 2007 08:44:17 +0300, Mik Kersten <beatmik@acm.org> wrote:
> Easiest thing to do is to install all of the latest Mylyn features from:
> http://www.eclipse.org/mylyn/downloads/
> If that still doesn't work, make sure you are using Java 5 or later and
> read through te following:
> http://wiki.eclipse.org/index.php/Mylyn_FAQ#Installation_Tro ubleshooting
> If the install still doesn't work please file a bug report so that we
> can diagnose further, and make sure to include any entries mentioning
> Mylyn in Window -> Show View -> PDE Runtime -> Error Log.
> Mik
>> extends its power.
| Re: focus on active task button is missing in Package Explorer [message #574908 is a reply to message #17474] |
Wed, 25 July 2007 01:44  |
Mik
| Re: focus on active task button is missing in Package Explorer [message #574982 is a reply to message #17474] |
Wed, 25 July 2007 03:22  |
I think I saw a similar problem, but I can't remember if it was with
Mylar 1.0 or with Mylyn 2.0.
If I remember well, in my case, simply deactivating and re-activating
the task did the job. Also try to check and uncheck the "Toggle focused
mode on navigator views when task is activated" in Mylyn context
preferences: the problem in my case might have arisen when that option
was unchecked...
Hope to have been of any help.
Mauro.
| Re: focus on active task button is missing in Package Explorer [message #575876 is a reply to message #18927] |
> Mik
>> extends its power.
FUDForum. Page generated in 0.03823 seconds
