Home » Archived » BIRT » Birt Capabilities?
Birt Capabilities? [message #185011] Tue, 15 August 2006 10:44 Go to next message
Hello, I'm new to BIRT. I was wondering if BIRT is able to generate a
chart dynamically; where the user will input data thru a JSP and then hit
a submit button and the servlet will display the data in a chart.
Thank you very much for your help.
Sincerely
Yeri Fer
Re: Birt Capabilities? [message #185054 is a reply to message #185011] Tue, 15 August 2006 11:17 Go to previous message
Yes, this is supported. A good place to start is to download the chart
engine from the BIRT web site, you will get an examples plugin. In that
plugin, there is a "preferences" example which is a JSP page displaying a
chart, and you can change some of the chart settings on the Web page, then
regenerate the chart. You just have to change the code to input data instead
and pass it to the chart engine.
David
"Yeri Fer" <silentdreamer10_4@yahoo.com> wrote in message
news:1e57be276371e9d07b9978adba818bb4$1@www.eclipse.org...
> Sincerely
> Yeri Fer
Previous Topic:Problem with PageBreak in Row
Next Topic:Rendering report emebedded charts directly to PDF
Current Time: Sat Jul 26 14:45:19 EDT 2025
Powered by FUDForum. Page generated in 0.02710 seconds
