Home » Language IDEs » ServerTools (WTP) » problem debugging Tomcat application
problem debugging Tomcat application [message #184950] Fri, 15 December 2006 07:51 Go to next message
I have this strange behaviour which I can reproduce anytime:
The application is running in Tomcat in debug mode. A breakpoint is set.
I reach the breakpoint and inspect some variables. When I hit resume
WTP tries to start the server without stopping it first. An error
message appears that the server's port are already taken. Well, no
surprise, of course they are.
This makes debugging almost useless. Did I find a bug or is it just my
environment?
I use the newest stable Eclipse release, WTP 1.5.2, Tomcat 5.5.20, all
on WinXP.
Andy
Re: problem debugging Tomcat application [message #184966 is a reply to message #184950] Fri, 15 December 2006 08:12 Go to previous messageGo to next message
Problem solved: I made an online update (there was a more recent WTP
version available) and now it works.
Andy
> environment?
> on WinXP.
> Andy
Re: problem debugging Tomcat application [message #184974 is a reply to message #184950] Fri, 15 December 2006 08:17 Go to previous messageGo to next message
I have not seen this behavior, but I may be using different UI. When
you try to resume, what UI are you using?
Larry
> environment?
> on WinXP.
> Andy
Re: problem debugging Tomcat application [message #185015 is a reply to message #184974] Fri, 15 December 2006 10:19 Go to previous message
That was the "Resume"-button in the "Debug"-view.
It happened once again, but after the update it is not reproducible anymore.
Andy
> Cheers,
> Larry
Previous Topic:the xdoclet integration needs serious re-factoring or at least enhancement
Next Topic:Creating a web service from wsdl (Top Down Java Bean Web Service)
Current Time: Sun Aug 31 23:52:03 EDT 2025
Powered by FUDForum. Page generated in 0.03347 seconds
