Home » Language IDEs » C / C++ IDE (CDT) » Finding the class given a CPPASTBaseSpecifier
Finding the class given a CPPASTBaseSpecifier [message #184613] Wed, 14 February 2007 08:05 Go to next message
we are developing an application to export information from C++ code. I
therefore made a subclass of the CPPASTVisitor class.
I am stuck trying to export information regarding superclasses. When
visiting a class, I can get its superclasses (if any) by using the
method getBaseSpecifiers(). This returns me instances of class
CPPASTBaseSpecifier.
My problem is that I need to find the actual classes these specifiers
refer to, and I do not know how to go about it. In other words, how to
get to the class (a CPPASTCompositeTypeSpecifier) given a
CPPASTBaseSpecifier ?
Any help would be much appreciated...
--Roel Wuyts
Re: Finding the class given a CPPASTBaseSpecifier [message #184621 is a reply to message #184613] Wed, 14 February 2007 08:50 Go to previous messageGo to next message
ICPPASTCompositeTypeSpecifier classSpecifier = getClassSpecifier() ;
List classList = getAllCompositeTypeSpecifierInTranslationUnit() ;
ICPPASTBaseSpecifier[] bases = classSpecifier.getBaseSpecifiers() ;
for( int i = 0 ; i < bases.length; i++ ) {
for( Iterator it = classList.iterator() ; it.hasNext(); ) {
ICPPASTCompositeTypeSpecifier sp =
(ICPPASTCompositeTypeSpecifier)it.next() ;
if(
sp.getName().resolveBinding().equals(bases[i].getName().reso lveBinding()) )
// sp is a immediate base class of classSpecifier
"Roel Wuyts" <roel.wuyts@gmail.com> ??????:eqv1fa$lu3$1@utils.eclipse.org...
> Hello,
> visiting a class, I can get its superclasses (if any) by using the method
> refer to, and I do not know how to go about it. In other words, how to get
> to the class (a CPPASTCompositeTypeSpecifier) given a CPPASTBaseSpecifier
> --Roel Wuyts
Re: Finding the class given a CPPASTBaseSpecifier [message #184664 is a reply to message #184621] Wed, 14 February 2007 10:35 Go to previous messageGo to next message
The key point here is the
bases[i].getName().resolveBinding()
I would hope the rest of this is not necessary since it is doing alot of extra work.
The resolveBinding on the name from the base specifier should return you a
ICPPClassType. That should hopefully give you all the information you need
without going back to the ICPPASTCompositeTypeSpecifier.
If you do need to get back to the composite-type-spec, try
classTypeBinding.getCompositeTypeScope().getScopeName(), that might get you back
to the IASTName in the composite-type-spec without having to resolve all the
other classes in the translation unit.
-Andrew
> if(
>> Hello,
>> --Roel Wuyts
Re: Finding the class given a CPPASTBaseSpecifier [message #184678 is a reply to message #184664] Wed, 14 February 2007 19:36 Go to previous messageGo to next message
>back to the IASTName in the composite-type-spec without having to resolve
>all the other classes in the translation unit.
I didn't quite catch up with you. Could you please give some sample code to
show how to achieve this?
"Andrew Niefer" <aniefer@ca.ibm.com>
??????:eqva7o$1l0$1@utils.eclipse.org...
> extra work.
> need without going back to the ICPPASTCompositeTypeSpecifier.
> you back to the IASTName in the composite-type-spec without having to
> resolve all the other classes in the translation unit.
> -Andrew
>> if(
>>> Hello,
>>> --Roel Wuyts
Re: Finding the class given a CPPASTBaseSpecifier [message #184820 is a reply to message #184621] Thu, 15 February 2007 15:32 Go to previous messageGo to next message
Thanks a lot! Comparing the resolved bindings is indeed what I needed.
> if(
>> Hello,
>> --Roel Wuyts
Re: Finding the class given a CPPASTBaseSpecifier [message #184993 is a reply to message #184678] Fri, 16 February 2007 18:24 Go to previous message
Tim,
I was thinking of something like this:
ICPPASTCompositeTypeSpecifier classSpecifier = getClassSpecifier();
ICPPASTBaseSpecifier[] bases = classSpecifier.getBaseSpecifiers();
IBinding binding = bases[i].getName().resolveBinding();
if( binding instanceof ICPPClassType)
IScope scope = ((ICPPClassType)binding).getCompositeScope();
IASTName name = scope.getScopeName();
if (name.getParent() instanceof ICPPASTCompositeTypeSpecifier)
//name.getParent() is the composite-type-spec that bases[i]
//refers to
Note that I haven't actually tried this, but if it works, then the savings are:
1) you don't need to getAllCompositeTypeSpecifierInTranslationUnit() ;
2) more importantly, you don't need to sp.getName().resolveBinding() on every
single composite-type-spec in the translation unit.
As well, this could use more error checking, resolveBinding() could return an
IProblemBinding which is also a ICPPClassType. getCompositeScope() could return
null.
-Andrew
>> extra work.
>> -Andrew
>>> if(
>>>> Hello,
>>>> --Roel Wuyts
Previous Topic:Bring back "Open Declaration" please!
Next Topic:Error while installing CDT 4 on Solaris
Current Time: Thu Nov 20 10:21:22 EST 2025
Powered by FUDForum. Page generated in 0.07480 seconds
