Home » Eclipse Projects » Eclipse Platform » Debugging Controls Greyed Out
Debugging Controls Greyed Out [message #184516] Sun, 25 January 2004 07:31 Go to next message
Originally posted by: eclipse.kesfan.net
I'm having a problem when trying to debug a Java application in Eclipse. I
start the debugger, my application starts and my breakpoint fires. I
switch back to the IDE and find my breakpoint in the source but when I go
to the 'run' menu all the debugging controls (step over, step into etc)
are greyed out and cannot be selected. Hitting the equivalent F keys
doesn't work either. The only way I can stop the debugging session is by
quitting Eclipse.
Has anyone seen a problem like this before? I am doing something dumb?
I have Eclipse 2.1.2, Win 2K and Java 1.4.1
With thanks for your help
LJ
Re: Debugging Controls Greyed Out [message #184585 is a reply to message #184516] Sun, 25 January 2004 12:39 Go to previous messageGo to next message
Do you have the debug view visible?
You can always terminate a debug session via the Console "Terminate" button
(the red square in the Console toolbar)
HTH
Darins
"Leon" <eclipse@kesfan.net> wrote in message
news:bv0cuv$s1s$1@eclipse.org...
> quitting Eclipse.
> LJ
Re: Debugging Controls Greyed Out [message #184616 is a reply to message #184585] Sun, 25 January 2004 14:09 Go to previous messageGo to next message
Thanks for your reply. Yes I have it set to the debug perspective and I
can see the options 'resume', 'suspend', 'terminate', 'step over' etc in
the run menu when I start up a debugging session. However all the options
are greyed out all the time and cannot be selected.
My breakpoints are working and when I roll the mouse over variables I get
a tooltip telling me the current value of the variable. So it is debugging
it's just these menu options are not available for some reason.
The terminate button on the console does terminate the debug session
though thanks however I can't debug because I can't click the 'step over'
option etc.
> HTH
> Darins
> > Hi,
> > quitting Eclipse.
> > LJ
Re: Debugging Controls Greyed Out [message #184638 is a reply to message #184616] Sun, 25 January 2004 15:28 Go to previous messageGo to next message
Originally posted by: dbyy.com.canada
hi Leon,
I have the same problem with Eclipse V3 M6.
I can 'run' my sample but Stepping through in debug mode is not possible.
What did I do wrong?
I used Eclipse at my office and it's working fine there.
Hope someone can help.
TIA
dbyy
> option etc.
>>HTH
>>Darins
>>>Hi,
>>>quitting Eclipse.
>>>LJ
Re: Debugging Controls Greyed Out [message #184654 is a reply to message #184616] Sun, 25 January 2004 16:30 Go to previous messageGo to next message
Can you use the actions in the toolbar of the Debug view for stepping
(Window>Show View>Debug if in the Debug perspective)?
Darins
news:bv14a7$ldn$1@eclipse.org...
> option etc.
button
> > HTH
> > Darins
> > > Hi,
Eclipse. I
go
etc)
by
> > > quitting Eclipse.
> > > LJ
Re: Debugging Controls Greyed Out [message #184902 is a reply to message #184516] Mon, 26 January 2004 09:15 Go to previous messageGo to next message
The debug view has to be open. The selection in the debug view drives the
stepping actions.
Darin Wright
> quitting Eclipse.
> LJ
Re: Debugging Controls Greyed Out [message #185180 is a reply to message #184654] Mon, 26 January 2004 17:58 Go to previous messageGo to next message
Ahhhh....that's got it. Yep, if I open that debug view panel as you
suggest below the items in the run menu become available. If you close
that panel the controls in the menu are greyed out and disabled.
Thanks very much for your help.
LJ
> Darins
> > option etc.
> button
> > > HTH
> > > Darins
> > > > Hi,
> Eclipse. I
> go
> etc)
> by
> > > > quitting Eclipse.
> > > > LJ
Re: Debugging Controls Greyed Out [message #1822309 is a reply to message #184516] Tue, 03 March 2020 12:46 Go to previous message
Hi there,
I had this issue as well.
I had JUnit tests running and they would quit, so just clicking "Keep JUnit running after a test run when debugging" in the debug configuration settings area where you created the debug test.
Hope this helped.
Previous Topic:2019-12 hover debug display problems
Next Topic:Eclipse 2018-09 and Amazon Corretto
Current Time: Wed Jul 16 21:26:00 EDT 2025
Powered by FUDForum. Page generated in 0.05835 seconds
