| riena and rcp plugin [message #1481] |
Fri, 16 May 2008 05:00  |
hi,
i'm trying to use an rcp application with a riena server.
this rcp application was working directly with hibernate without server
so i put the hibernate/service to the riena server part plugin
so the server contains my business services
and it works fine
i've set up a test client calling a service. and it works fine
but when i import my rcp plugin in my workspace,
i have some compilation problem because of missing plugins in the target
platform (downloaded from riena wiki)
mainly ressourcePlugin, FileSystem, ui.forms, ui.editors and IDE
do you think, it can work if i copy these plugins from another eclipse
directory ??
tia
David
| Re: riena and rcp plugin [message #1491 is a reply to message #1481] |
Fri, 16 May 2008 10:30   |
Hi David,
you can add more plugins to the target platform as needed. The platform that we supply is based on Eclipse 3.3. So its
probably a code choice to your own plugings also from Eclipse 3.3. Other than that, there should be no problem at all.
Try it and if there are problems, let me know.
christian campo
news.eclipse.org schrieb:
> hi,
> and it works fine
> directory ??
> tia
> David
| Re: riena and rcp plugin [message #1504 is a reply to message #1491] |
Mon, 19 May 2008 03:40  |
hi Christian,
thanks for your answer
it works fine.
i've just copied all the needed plugins to my target platform directory
"Christian Campo" <christian.campo@compeople.de> wrote in message
news:482D9A6B.4020302@compeople.de...
> Hi David,
> that we supply is based on Eclipse 3.3. So its probably a code choice to
> no problem at all.
> christian campo
>> hi,
>> and it works fine
>> directory ??
>> tia
>> David
| Re: riena and rcp plugin [message #570223 is a reply to message #1481] |
Hi David,
christian campo
> hi,
> and it works fine
> directory ??
> tia
> David
| Re: riena and rcp plugin [message #570236 is a reply to message #1491] |
hi Christian,
it works fine.
> Hi David,
> no problem at all.
> christian campo
>> hi,
>> and it works fine
>> directory ??
>> tia
>> David
FUDForum. Page generated in 0.03726 seconds
