Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Build failure
PDE Build failure [message #17360] Mon, 25 August 2008 11:34 Go to next message
Hi guys,
We have a problem with our headless build (using PDE build). We have an
OutOfMemoryError thrown out during the compilation phase. There is
specific cases though where it works and where it fails with the mentioned
exception.
Failure case:
We're building on Windows and we have the "baseLocation" properties set to
target our local Eclipse 3.3 installation directory.
Success case:
We have a special directory located on a linux machine that have *only*
the required libraries to build our plugins. The plugins were copied from
the local Eclipse 3.3 installation directory. When we target this
directory with our Windows build, it works.
Thoughts:
(I'm providing the relevant section of the log where the build fails. If
you want more of it or all, just tell me and I'll send it to you
individually or on an agreed protocol.)
I might be wrong here as I don't know the underlying code but by looking
at the log, it strikes me as odd that there is so much calls to the
'ProjectHelper.addLocationToBuildException' method. Could it be possible
that some error reporting process is suffering from recursive problem,
trying to chase its own tail?
Also, there is no difference in our properties configuration when building
with the local Eclipse installation directory or the specially crafted
one, except for the "baseLocation" property itself. Hence why would the
build crash when we specify our local Eclipse installation directory?
We've tested this behaviour on two different machines with the same
results. Is it possible that having more than the required plugins might
pose a problem during the headless build? Would Eclipse try to resolve
*all* plugins, even unneeded ones, and have some problem if one of them
misses a dependency?
I have no clue on why it would fail. It did work some weeks ago without a
problem (on Windows and targeting the local installation directory) but I
had to drop development on our headless build for some time and I
restarted this week with these strange results.
Thanks in advance,
Jimmy
===================================== LOG
[exec] generateScript:
[exec] Property "outputUpdateJars" has not been set [exec] Property
"archivesFormat" has not been set [exec] Property "forceContextQualifier"
has not been set [exec] Property "significantVersionDigits" has not been
set [exec] Property "generatedVersionLength" has not been set [exec]
Property "platformProperties" has not been set
[exec] [ant] Exiting
C:\shadows\std\xpi\modex-designer\trunk\src\modex.designer.p de.build\customTargets.xml.
[exec] [antcall] Exiting
C:\dev\tools\eclipseide\3.3prod\eclipse\plugins\org.eclipse. pde.build_3.3.2.R331_v20071019\scripts\productBuild\productB uild.xml.
[exec] BUILD FAILED
[exec]
C:\dev\tools\eclipseide\3.3prod\eclipse\plugins\org.eclipse. pde.build_3.3.2.R331_v20071019\scripts\productBuild\productB uild.xml:27:
The following error occurred while executing this line:
[exec]
C:\dev\tools\eclipseide\3.3prod\eclipse\plugins\org.eclipse. pde.build_3.3.2.R331_v20071019\scripts\build.xml:64:
[exec]
C:\shadows\std\xpi\modex-designer\trunk\src\modex.designer.p de.build\customTargets.xml:10:
java.lang.OutOfMemoryError: Java heap space
[exec] at
org.apache.tools.ant.ProjectHelper.addLocationToBuildExcepti on(ProjectHelper.java:541)
[exec] at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:418)
[exec] at
org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:105)
[exec] at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
[exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[exec] at
[exec] at
[exec] at java.lang.reflect.Method.invoke(Method.java:597)
[exec] at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:105)
[exec] at org.apache.tools.ant.Task.perform(Task.java:348)
[exec] at org.apache.tools.ant.Target.execute(Target.java:357)
[exec] at org.apache.tools.ant.Target.performTasks(Target.java:385)
[exec] at
org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1329)
[exec] at org.apache.tools.ant.Project.executeTarget(Project.java:1298 )
[exec] at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
[exec] at
org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
[exec] at org.apache.tools.ant.Project.executeTargets(Project.java:118 1)
[exec] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:623)
[exec] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:495)
[exec] at
[exec] at
[exec] at org.eclipse.ant.core.AntRunner.run(AntRunner.java:512)
[exec] at org.eclipse.ant.core.AntRunner.start(AntRunner.java:599)
[exec] at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
[exec] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
[exec] at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
[exec] at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
[exec] Caused by:
[exec]
[exec] at
[exec] at
[exec] at sun.reflect.GeneratedMethodAccessor31.invoke(Unknown Source)
[exec] at
[exec] at
[exec] at
[exec] at
org.apache.tools.ant.helper.SingleCheckExecutor.executeTarge ts(SingleCheckExecutor.java:38)
[exec] at
org.eclipse.ant.internal.core.ant.EclipseSingleCheckExecutor .executeTargets(EclipseSingleCheckExecutor.java:30)
[exec] at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:416)
[exec] ... 36 more
[exec] Caused by:
[exec] at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:115)
[exec] at
[exec] at
[exec] at
[exec] ... 49 more
[exec] Caused by: java.lang.OutOfMemoryError: Java heap space [exec] ---
Nested Exception --- [exec]
[exec]
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] Caused by:
[exec] at
[exec] at
[exec] at
[exec] at
[exec] ... 49 more
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
Nested Exception --- [exec] java.lang.OutOfMemoryError: Java heap space
[exec] Total time: 3 minutes 58 seconds
[exec] !ENTRY org.eclipse.osgi 4 0 2008-08-13 19:48:05.274 [exec] !MESSAGE
Application error [exec] !STACK 1 [exec]
java.lang.reflect.InvocationTargetException
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] Caused by:
[exec]
[exec]
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] ... 19 more
[exec] Caused by:
[exec]
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] ... 36 more
[exec] Caused by:
[exec] at
[exec] at
[exec] at
[exec] at
[exec] ... 49 more
[exec] Caused by: java.lang.OutOfMemoryError: Java heap space [exec] Root
exception:
[exec]
[exec]
[exec]
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] Caused by:
[exec]
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] ... 36 more
[exec] Caused by:
[exec] at
[exec] at
[exec] at
[exec] at
[exec] ... 49 more
[exec]
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] Caused by:
[exec] at
[exec] at
[exec] at
[exec] at
[exec] ... 49 more
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] !ENTRY org.eclipse.jdt.core 4 0 2008-08-13 19:48:20.222 [exec]
!MESSAGE [exec] !STACK 0 [exec] org.osgi.framework.BundleException:
Exception in org.eclipse.jdt.core.JavaCore.stop() of bundle
[exec] at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1056)
[exec] at
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:457)
[exec] at
org.eclipse.osgi.framework.internal.core.AbstractBundle.susp end(AbstractBundle.java:526)
[exec] at
org.eclipse.osgi.framework.internal.core.Framework.suspendBu ndle(Framework.java:1148)
[exec] at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ecFWSL(StartLevelManager.java:675)
[exec] at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:291)
[exec] at
org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:261)
[exec] at
org.eclipse.osgi.framework.internal.core.SystemBundle.suspen d(SystemBundle.java:188)
[exec] at
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:622)
[exec] at
org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:525)
[exec] at
org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.jav a:41)
[exec] at
org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(Ecl ipseStarter.java:399)
[exec] at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:197)
[exec] at
[exec] at
[exec] Caused by: java.lang.NoClassDefFoundError: Could not initialize
class org.eclipse.core.internal.jobs.JobMessages
[exec] at
org.eclipse.core.internal.jobs.JobManager.join(JobManager.ja va:751)
[exec] at
org.eclipse.jdt.internal.core.JavaModelManager.shutdown(Java ModelManager.java:4228)
[exec] at org.eclipse.jdt.core.JavaCore.stop(JavaCore.java:4701)
[exec] at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$3 .run(BundleContextImpl.java:1040)
[exec] at java.security.AccessController.doPrivileged(Native Method)
[exec] at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1036)
[exec] ... 20 more
[exec] Root exception:
[exec] java.lang.NoClassDefFoundError: Could not initialize class
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
[exec] at
Re: PDE Build failure [message #19065 is a reply to message #17360] Wed, 03 September 2008 10:41 Go to previous messageGo to next message
All the heavy lifting performed by PDE/Build is over and done before
compilation begins. This could be a bug in the jdt compiler.
If your log indicates which bundle was being compiled, I would suggest
looking at the generated build.xml and comparing the classpath between
the failure and success cases. You can try running the "build.jars"
target for that bundle in isolation.
If you can reproduce just by calling the compiler instead of the entire
build process, then you can raise a bug on the JDT guys.
I suspect the addLocationToBuildException calls are just the result of
additional memory problems while trying to recover.
-Andrew
Jimmy Royer wrote:
> Hi guys,
> mentioned exception.
> Failure case:
> to target our local Eclipse 3.3 installation directory.
> Success case:
> from the local Eclipse 3.3 installation directory. When we target this
> Thoughts:
> building with the local Eclipse installation directory or the specially
> crafted one, except for the "baseLocation" property itself. Hence why
> would the build crash when we specify our local Eclipse installation
> directory? We've tested this behaviour on two different machines with
> the same results. Is it possible that having more than the required
> plugins might pose a problem during the headless build? Would Eclipse
> try to resolve *all* plugins, even unneeded ones, and have some problem
> if one of them misses a dependency?
> a problem (on Windows and targeting the local installation directory)
> but I had to drop development on our headless build for some time and I
> Thanks in advance,
> Jimmy
> "forceContextQualifier" has not been set [exec] Property
> "significantVersionDigits" has not been set [exec] Property
> "generatedVersionLength" has not been set [exec] Property
> [exec] BUILD FAILED
> [exec]
> [exec]
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] Caused by:
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 36 more
> [exec] Caused by:
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 49 more
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] Caused by:
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 49 more
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> !MESSAGE Application error [exec] !STACK 1 [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] Caused by:
> [exec]
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 19 more
> [exec] Caused by:
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 36 more
> [exec] Caused by:
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 49 more
> Root exception:
> [exec]
> [exec]
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] Caused by:
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 36 more
> [exec] Caused by:
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 49 more
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] Caused by:
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 49 more
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 20 more
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
Re: PDE Build failure [message #20053 is a reply to message #19065] Sat, 06 September 2008 22:35 Go to previous message
Originally posted by: wbeckwith.gmail.com
I actually have the reverse where amazingly the build runs fine on
windows with 384M of memory, but no matter how much I give it on linux
(up to 2GB) it still fails with the following trimmed down stacktrace
/opt/builds/teamcity/agent/work/9cd033919381f6f7/eclipse/lis a-ui.builder/build/plugins/com.itko.lisa.runtime.compatibili ty/build.xml:415:
org.eclipse.jdt.core.JDTCompilerAdapter.execute(JDTCompilerA dapter.java:88)
at org.apache.tools.ant.taskdefs.Javac.compile(Javac.java:997)
at org.apache.tools.ant.taskdefs.Javac.execute(Javac.java:820)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1329)
... 156 more
Caused by: java.lang.reflect.InvocationTargetException
org.eclipse.jdt.core.JDTCompilerAdapter.execute(JDTCompilerA dapter.java:79)
... 171 more
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:203)
at java.util.zip.ZipFile.<init>(ZipFile.java:234)
org.eclipse.jdt.internal.compiler.batch.ClasspathJar.initial ize(ClasspathJar.java:260)
org.eclipse.jdt.internal.compiler.batch.ClasspathJar.fetchLi nkedJars(ClasspathJar.java:168)
org.eclipse.jdt.internal.compiler.batch.Main.handleClasspath (Main.java:2944)
at org.eclipse.jdt.internal.compiler.batch.Main.setPaths(Main.j ava:3946)
at org.eclipse.jdt.internal.compiler.batch.Main.configure(Main. java:2640)
at org.eclipse.jdt.internal.compiler.batch.Main.compile(Main.ja va:1625)
... 176 more
Executing the generated build file manual gives
[me@adari com.itko.lisa.runtime.compatibility]$
/opt/builds/resources/apache-ant-1.7.0/bin/ant build.jars
Buildfile: build.xml
properties:
init:
build.jars:
properties:
init:
@dot:
[delete] Deleting directory
/opt/builds/teamcity/agent/work/9cd033919381f6f7/eclipse/lis a-ui.builder/build/plugins/com.itko.lisa.runtime.compatibili ty/temp.folder/@dot.bin
[mkdir] Created dir:
[javac] Compiling 1 source file to
381f6f7/eclipse/lisa-ui.builder/build/plugins/com.itko.lisa. runtime.compatibility/temp.folder/@dot.bin
[javac]
/opt/builds/teamcity/agent/work/9cd033919381f6f7/eclipse/lis a-ui.builder/build/plugins/com.itko.lisa.runtime.compatibili ty/src/com/itko/lisa/runtime
/compatibility/RuntimeCompatibilityPlugin.java:44: annotations are not
supported in -source 1.3
[javac] (use -source 5 or higher to enable annotations)
[javac] @Override
[javac] ^
[javac]
/compatibility/RuntimeCompatibilityPlugin.java:80: for-each loops are
not supported in -source 1.3
[javac] (use -source 5 or higher to enable for-each loops)
[javac] for (String entry : entries)
[javac] ^
[javac] 2 errors
[javac] Compile failed; see the compiler error output for details.
[copy] Copying 1 file to
[copy] Copied 5 empty directories to 3 empty directories under
/opt/builds/teamcity/agent/work/9cd033919381f6f7/eclipse/lis a-ui.builder/build/plugins/com.itko.lisa.runtime.compatibili ty/@dot
[copy] Copied 6 empty directories to 2 empty directories under
BUILD SUCCESSFUL
Total time: 2 seconds
The plug-in in question actually only has i file in it the Activator
with the rest being jars that makeup the classpath to export to
downstream plug-ins.
At a lost as to why this continues to fail on linux.
Wb
> -Andrew
Re: PDE Build failure [message #578443 is a reply to message #17360] Wed, 03 September 2008 10:41 Go to previous message
-Andrew
Jimmy Royer wrote:
> Hi guys,
> Failure case:
> Success case:
> Thoughts:
> Thanks in advance,
> Jimmy
> [exec] BUILD FAILED
> [exec]
> [exec]
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] Caused by:
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 36 more
> [exec] Caused by:
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 49 more
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] Caused by:
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 49 more
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] Caused by:
> [exec]
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 19 more
> [exec] Caused by:
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 36 more
> [exec] Caused by:
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 49 more
> Root exception:
> [exec]
> [exec]
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] Caused by:
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 36 more
> [exec] Caused by:
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 49 more
> [exec]
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] Caused by:
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 49 more
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] ... 20 more
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
> [exec] at
Re: PDE Build failure [message #579014 is a reply to message #19065] Sat, 06 September 2008 22:35 Go to previous message
... 156 more
... 171 more
... 176 more
properties:
init:
build.jars:
properties:
init:
@dot:
[javac]
[javac] @Override
[javac] ^
[javac]
[javac] ^
[javac] 2 errors
BUILD SUCCESSFUL
Wb
> -Andrew
Previous Topic:PDE tutorial?
Next Topic:Problem with p2 and version qualifiers
Current Time: Sat Nov 08 15:46:28 EST 2025
Powered by FUDForum. Page generated in 0.04351 seconds
