Home » Newcomers » Newcomers » Eclipse based ( RCP ) product not picking up the plugins
Eclipse based ( RCP ) product not picking up the plugins [message #17354] Thu, 27 January 2005 01:41 Go to next message
Originally posted by: rathdeep.yahoo.com
I have one eclipse based product built on RCP platform.
I have created a plugin to add shortcuts to this product's workbench.
After creating the plugin ; i exported this to products\plugins dir.
And when i reopened the product's workbench ; I could see the shortcuts
addded to it. ( on machine X )
But my problem is I am not able to see the shortcuts on product's
workbench on my my dev. machine.
So i want to know if there is any settings that the workbench looks before
picking up the plugins. I have got some extra environment variables set in
dev. machine.
Thanks in advance,
DC
Re: Eclipse based ( RCP ) product not picking up the plugins [message #18210 is a reply to message #17354] Thu, 27 January 2005 11:08 Go to previous messageGo to next message
Not sure which version of Eclipse you are using but likely you need to
specify -clean as a program argument to Eclipse when you are adding new
plugins.
HTH
Darins
"dc" <rathdeep@yahoo.com> wrote in message
news:cta2fc$r0l$1@www.eclipse.org...
> workbench on my my dev. machine. So i want to know if there is any
> settings that the workbench looks before picking up the plugins. I have
> got some extra environment variables set in dev. machine.
> Thanks in advance,
> DC
Re: Eclipse based ( RCP ) product not picking up the plugins [message #19332 is a reply to message #18210] Fri, 28 January 2005 01:24 Go to previous messageGo to next message
Hi Darin , Thanks for the response. I am using Eclipse 3.0.1,JDK 1.5.
When i invoke eclipse based product from eclipse workbench; plugin gets
added.
But when i open product exe directly ; its is not picking up the plugins
Any idea....
DC
> plugins.
> HTH
> Darins
>> After creating the plugin ; i exported this to productsplugins dir.
>> Thanks in advance,
>> DC
Re: Eclipse based ( RCP ) product not picking up the plugins [message #19602 is a reply to message #19332] Fri, 28 January 2005 07:54 Go to previous message
Thanks Darin ; it works with clean option.
> added.
> Any idea....
> DC
>> plugins.
>> HTH
>> Darins
>>> Thanks in advance,
>>> DC
Previous Topic:Spring Framework plug in not installing
Next Topic:Extending my own extension point
Current Time: Mon Nov 10 20:27:25 EST 2025
Powered by FUDForum. Page generated in 1.07844 seconds
