| Build where source dir is not root of project fails [message #17313] |
Tue, 18 March 2003 21:11  |
Originally posted by: bradley.greystate.com
I have been attempting to get AJDT working under eclipse 2.1, both RC1
and Rc2. I have tried building the AspectJ examples in the workbench
using seperately AJDT 0.5.2 and 1.1.1rc1.
My only success I have, is when I have a project defined with the java
source build path as the root of the project.
If the project has source in a subdirectory (such as src/ as the default
layout of a project in eclipse) build fails.
Is this expected behavior, or am I missing something here?
Thanks for your thoughts,
Bradley
| Re: Build where source dir is not root of project fails - bug [message #17359 is a reply to message #17338] |
Wed, 19 March 2003 01:53  |
Interestingly, if I make sure that the name of the project is the same
as the root directory of the project, I can now compile the samples.
All except the Telecoms one, but that appears to be due to the evolution
of the langage rather than the tool.
Previously, I had the project called aspectj-samples, linked to the
directory workspace/aspectj. The builder process was creating a
directory in the workspace called aspectj-samples and building into that.
Thanks for the help,
bradley
Mark wrote:
> this works fine for me.
> i have all my java as source as well as aspectj source
> under a src/ directory.
> -- mark
> Bradley wrote:
>> default layout of a project in eclipse) build fails.
>> Bradley
| Re: Build where source dir is not root of project fails [message #564862 is a reply to message #17313] |
Tue, 18 March 2003 22:47  |
-- mark
Bradley wrote:
> Bradley
| Re: Build where source dir is not root of project fails - bug [message #564886 is a reply to message #17338] |
bradley
> -- mark
> Bradley wrote:
>> Bradley
FUDForum. Page generated in 0.03844 seconds
