Home » Eclipse Projects » Subversive » Can't update Subversive
Can't update Subversive [message #17312] Thu, 24 April 2008 19:30 Go to next message
I used the following update site to install Subversive a while ago:
http://download.eclipse.org/technology/subversive/0.7/update -site/
Now when I do "Software Updates > Find and Install..." there is the
following error:
Network connection problems encountered during search.
Unable to access
" http://www.eclipse.org/downloads/download.php?file=/technolo gy/subversive/0.7/update-site/".
Error parsing site stream. [The XML stream is not a valid default
"site.xml" file. The root tag is not site.]
The XML stream is not a valid default "site.xml" file. The root tag is
not site.
not site.
Looks like there is a redirection to a mirror site selection page?!
Re: Can't update Subversive [message #17765 is a reply to message #17312] Fri, 25 April 2008 05:26 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Eric,
It looks like failure with update site mirrors. Please try to update
plug-in from the main update site (it definitely works fine). Another
possible reason is network failure.
Re: Can't update Subversive [message #17796 is a reply to message #17765] Fri, 25 April 2008 21:23 Go to previous message
Just removed and re-installed Subversive, working fine now.
Previous Topic:red exclamation mark on folders?
Next Topic:PDE Build
Current Time: Tue Nov 04 11:41:17 EST 2025
Powered by FUDForum. Page generated in 0.04515 seconds
