| ConstraintProvider extension point [message #17289] |
Wed, 18 April 2007 10:24  |
Originally posted by: vincent.legloahec.gmail.com
Hi everyone,
I'm developing a GMF editor which already use OCL constraints to validate
the diagram. It uses Audit Rules which work fine.
I would like to separate the definition of those rules from the editor
code. So I created a new plugin, declaring the constraintProvider
extension point, as it was previously defined in my GMF editor.
By now I can see those new rules in the Preference page (under Model
validation -> Constraints), but when I validate my diagram nothing
happens, no constraint is called by the batch validator.
Did I forget something ?
Thanks in advance.
Here is my constraintprovider extension :
N.B. namespaceUri="http://www.exemple.com/" is the same as the uri
definied in my ecore model.
<extension point="org.eclipse.emf.validation.constraintProviders">
<category id="constraints.category2"
mandatory="false"
name="category2">
</category>
<constraintProvider cache="true">
<package namespaceUri="http://www.exemple.com/">
</package>
<constraints categories="constraints.category2">
<constraint
id="constraints.constraint2"
lang="OCL"
mode="Batch"
name="constraint2"
severity="ERROR"
statusCode="11">
<![CDATA[ self.name.size() > 0 ]]>
<message>
message body text
</message>
<description>
description body text
</description>
<target
class="alk_comp.Component">
</target>
</constraint>
</constraints>
</constraintProvider>
</extension>
| Re: [Validation] ConstraintProvider extension point [message #17315 is a reply to message #17289] |
Wed, 18 April 2007 10:39  |
Hi, Vincent,
This isn't the correct newsgroup for EMF Validation-related questions. I'm
including eclipse.technology.emft for the benefit of other validation
users.
After you run validation, do you see any entries in the workspace log file?
Perhaps something indicating that the target EClass "alk_comp.Component"
could not be resolved?
Otherwise, I would check whether GMF perhaps generates a clientContext for
which you would need to define a binding on the
org.eclipse.emf.validation.constraintBindings extension point, to bind your
constraint category to that context.
HTH,
Christian
Vincent wrote:
> Hi everyone,
> Thanks in advance.
> mandatory="false"
> name="category2">
> </category>
> </package>
> <constraint
> lang="OCL"
> mode="Batch"
> name="constraint2"
> severity="ERROR"
> statusCode="11">
> <message>
> message body text
> </message>
> <description>
> </description>
> <target
> </target>
> </constraint>
> </constraints>
> </extension>
FUDForum. Page generated in 0.08274 seconds
