Home » Archived » XML Schema Definition (XSD) » XML Schema Generation and <!DOCTYPE>-statements: How to?
XML Schema Generation and <!DOCTYPE>-statements: How to? [message #17267] Thu, 10 April 2003 13:29 Go to next message
Originally posted by: dirk.schesmer.divos.de
Hi all,
I'd like to know whether XSD can handle the <!DOCTYPE portions (being
optional, but still in heavy use) specified in the header part of an
XSD-file, as well. I did not find an API for it.
You see, e.g. XMLSchema.xsd until recently contained something like:
<!DOCTYPE xs:schema PUBLIC "-//W3C//DTD XMLSCHEMA 200102//EN"
"XMLSchema.dtd" [
<!-- provide ID type information even for parsers which only read the
internal subset -->
and the document world is still governed by DTDs...
Thanks, Dirk V. Schesmer
Re: XML Schema Generation and <!DOCTYPE>-statements: How to? [message #17366 is a reply to message #17267] Thu, 10 April 2003 14:24 Go to previous message
Dirk,
Sometimes these DOCTYPE things will require loading DTDs that are "hard
to find", so it may fail because of that. There is nothing in the XSD
model to access DOCTYPE information, but it will be available in the
underlying DOM (i.e., xsdSchema.getDocument()).
"Dirk V. Schesmer" wrote:
> Hi all,
> "XMLSchema.dtd" [
> internal subset -->
Re: XML Schema Generation and <!DOCTYPE>-statements: How to? [message #567611 is a reply to message #17267] Thu, 10 April 2003 14:24 Go to previous message
Dirk,
> Hi all,
> "XMLSchema.dtd" [
> internal subset -->
Previous Topic:Automatic Schema validation?
Next Topic:Automatic Schema validation?
Current Time: Fri Nov 14 03:55:47 EST 2025
Powered by FUDForum. Page generated in 0.03640 seconds
